Beam/ column joins
What does that tool really do? Is it for joining beams to columns, or beams to beams and columns to columns. I have a UC vertical column at intervals on my plan which are supposed to receive each a beam connection angled at 30deg. Then from each of these beams is another beam at a different angle. I am trying to join the last beam to the first beam and the whole to the column. I can't figure out how this tool work; whenever I try this the other beam is grayed out. And even how do i join my beam to the column. I am using Revit Architecture not Structure but this tool exists in it. So how does one use it. I have read in places that you have to use reference plane as a cut plane, but whenever I try to do this in elevation my beams and column display only as lines, why is that? I cannot see the beam and columns shapes in elevation to draw the reference plane at their intersection. Can someone help?
