Referencing a detail in section
    I'm trying to reference a detail to by using a section. Trouble is when I reference the view and place the section, the section head and tail are not showing up. When I place a regular section view (not referencing anything) the head and tail show up. Everything is turned on in V/G so I'm not sure what i'm missing here. Let me know if anyone has run into this before!
    Thanks!
    The view that you are trying to reference... check the type of view that it is set to. You may need to change it from a Wall Section to a Building Section, or a Detail View.
    Also, for that view type, click <edit type> and check the Section Tag under Graphics.
    Leanne Zaras, CDT, LEED AP
      Ah, I needed to go one step deeper. In the <edit type> of my detail view it showed that I had a section head and tail chosen, but when I went into the option for that, they were both set to "none". Simply changed it to tag I wanted and it popped right up. Thanks Leannez!
