Any idea what may be causing this? Exporting from a 3D view.
Exporting DWG and DXF causing fatal error
This topic is closed.
Could you provide any more specifics on the issue? Exporting certain types of view? Sheets? Size of project? Etc? The more information, the better chance another seasoned vets in this forum may be able to identify the issue.
I have had similar/quirky instances of Revit crashing when trying to print or export PDF/DWG of certain sheets or views within a project. Unfortunately persistence and luck prevails and it sometimes clears up.Chris Washer
What is your end goal? Export model in 3D DWG to open in another program? There may be other formats you could try in that case, IFC, FBX, SAT possibly. If you need only a portion of the building use a scope box to hide/crop the parts that you don't need and try exporting that to any of the file types you are attempting.
Maybe make a copy of your model file, and try auditing the file, purging out unused families, and review/fix your warnings and see if any of that could be an issue. Then try export....
Sounds like some systematic troubleshooting is in order. Let us know if you uncover anything else.Chris Washer
Guys,
Trying to export something to DWG and somehow contents of Exported DWG shows up Blank. and some of them are missing some views. but...February 24, 2016, 09:27 PM -
Hey everybody,
My video speaks by itself so here it is:
Revit Won't Export to Cad - Alexandre-Cantin's library
First...July 20, 2012, 09:42 PM -
Hi there.
When I export a sheet with a Ground floor and first floor plan the resulting DWG has both the plans on top of one another....December 6, 2011, 04:23 AM -
We just got a 3D printer (very cool) and I'm experimenting with it.
A long time ago on a 2-week bicycle trip, I whittled a "Caged Ball"...June 11, 2015, 10:04 PM -
OK, this is strange. I spent a considerable amount of time creating an export file to dwg for a client. It was a work of art I tell you, any way, I open...November 15, 2012, 12:50 PM
