Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Why when i draw pipe it shows single line ??!
    Senior Member ahmed_hassan's Avatar
    April 25, 2011
    Egypt
    752
    07:52 AM
    Hi, it is strange when i draw pipe with diameter it shows line (Image attached)?!! why i saw this also when i tried to make layout for cooling tower with heat pump.
    Attached Thumbnails Attached Thumbnails Why when i draw pipe it shows single line ??!-1.jpg
    May 25, 2011
    192
    02:52 AM
    change Detail Level to something other than Coarse
    April 25, 2011
    Egypt
    752
    07:52 AM
    It is already changed as you can see in the picture attached beside Scale.
    May 25, 2011
    192
    02:52 AM
    Oops, I am on a roll today. hmm...
    April 25, 2011
    Egypt
    752
    07:52 AM
    Anyone have idea plzzz??!!!
    Administrator Ian.Kidston's Avatar
    Melbourne, Australia
    1,144
    06:52 PM
    What discipline is the view in? Architectural - Construction - Mechanical - Plumbing etc? Not sure if it is an issue in this case or not, however some elements display differently depending on the discipline.
    Moderator mark b's Avatar
    NSW Australia
    1,429
    05:52 PM
    Check detail levels. Course level will give you the issue you describe,
    Attached Thumbnails Attached Thumbnails Why when i draw pipe it shows single line ??!-pipe-problem.jpg
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,486
    12:52 AM
    Quote Originally Posted by mark b View Post
    ahem...see post #3
    NSW Australia
    1,429
    05:52 PM
    Yeah, OK, fools rush in.
    April 25, 2011
    Egypt
    752
    07:52 AM
    Guys who was in rush was me!!! what makes a surprise that coarse level is the same display view for medium(Strange for revit for the first time as in architecture it is usual that medium is often like Fine) !!! just when i changed to fine and make a thin lightweight i discovered that pipe is no more a single line, The Discipline was Mechanical .
    Sorry for bothering,
    and thanks all for your attempts to help.
  1. Pipe Fitting Connections to each other/NO Pipe
    By se13gits in forum MEP - General
    Last Post: July 8th, 2016, 01:56 PM
  2. Dumb Line Draw Order
    Last Post: March 27th, 2012, 01:33 AM
  3. Nothing shows up in 3D-View
    By VTHokies in forum Structure - General Questions
    Last Post: February 21st, 2012, 02:27 PM
  4. representation of beams is just single line !!!!!?
    Last Post: January 1st, 2012, 09:10 PM
  5. Shared/Project Parameters - where to draw the line...
    By snowyweston in forum Architecture - Family Creation
    Last Post: November 3rd, 2011, 12:54 AM
