Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By oj manlapaz
Thread: How to make new descipline to make under it levels ?
    Senior Member ahmed_hassan's Avatar
    April 25, 2011
    Egypt
    752
    01:26 AM
    I want to assign here MEP Design category and make under it plenmum levels could anyone tell me how?
    Attached Thumbnails Attached Thumbnails How to make new descipline to make under it levels ?-capture.jpg
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    08:26 PM
    I'm not quite sure what you are wanting to do. I wouldn't add a level for the plenum. I'd just model the plenum on an existing level.
    Oh, and by the way, you've got an extra M in your spelling.
    Junior Member oj manlapaz's Avatar
    October 14, 2011
    Philippines
    42
    09:26 AM
    Plenum levels are used to fill-in Space objects in the ceilings (most-often) and other unoccupied space. These are used IF Heating and Cooling Analysis will be done in Revit MEP. However, according to some designers, Revit analysis lacks in some departments, which is why they still use 3rd party softwares for analysis. After all, Revit is a modelling software.
    Going back to the question, just simply type "Plenum" under Sub-discipline Parameter in the View Properties for the View you want to categorize. I am assuming you are using a default template, and a default Browser Organization for MEP.
    April 25, 2011
    Egypt
    752
    01:26 AM
    ok my purpose is to add new value descipline not to rename existing one meaning : i want to have
    - HVAC.
    - Lighting.
    -Plumbing.
    -Power.
    -MEP Design.
    when i go inside view properties and typing inside sub descipline parameter new value it replace existing one, i need to add new fresh one not replacing
    Waiting help
    and thanks
    October 14, 2011
    Philippines
    42
    09:26 AM
    Here's the thing..
    If you have views that are using a particular Sub-discipline, it will still appear in the Project Browser. Meaning, if all views, let's say, under HVAC, are deleted or replaced, HVAC will no longer appear in your Browser.
    So, regarding your question, this is where Duplicate Views come into play. Duplicate your Views for each sub-discipline, then enter your sub-discipline on the DUPLICATES' View Properties. Once you have typed-in your Sub-disciplines, succeeding views can be changed by selecting from a drop-down selection of all USED sub-disciplines.
    ahmed_hassan and dzatto like this.
  1. Can't make type
    By tmariappan in forum MEP - Family Creation
    Last Post: January 19th, 2012, 06:01 AM
  2. Always Make A Duplicate!!
    Last Post: December 2nd, 2011, 03:02 PM
  3. Does this make sense?
    By flyguy202 in forum Architecture and General Revit Questions
    Last Post: September 26th, 2011, 10:59 PM
  4. how to make like this shape ?
    Last Post: September 21st, 2011, 10:36 PM
