Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Like Tree4Likes
Thread: Reference Plane Visibility
    December 14, 2011
    2
    04:51 AM
    I'm working off of a model created by another user and there are existing reference planes that fixtures are hosted to. I cannot seem to view these reference planes in section. I have created new reference planes that i can see/move/edit in section, but now that i need to move the existing reference planes i am unable to do so. I can still host fixtures to it, they appear when i edit the workplane of a fixture, but i cant see them in order to move them. Any ideas how to make these planes visible/editable?
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    02:51 AM
    Go into a 3D view, make sure there is nothing croping anything in your 3D view. Set your work plane to the troubled RP and click Show. This will show you the extents of the RP. Verify that the RP does in fact cut thru the section you are having trouble with. If it does cut thru the troubled section view... I am stumped... But more then likely the RP's extents are not being cut by your section.
    dzatto and cganiere like this.
    December 14, 2011
    2
    04:51 AM
    Thanks Alex.
    But that didnt seem to do the trick. It looks like the reference plane is encompasing the entire plan. Could it have to do with the reference plane being locked to any specific ceiling? And if so, is there somewhere i can see these properties and alter the location, etc.?
    December 8, 2010
    Northern California
    3,567
    02:51 AM
    Is the RP on a different Workset? Is it assigned to a Scope Box??? Is the RP hidden using Element Hide??? To the best of my knowledge you can't filers RPs...
    Maybe you can upload a striped down copy of your project for us to look at.
    October 30, 2014
    3
    09:51 AM
    reference planes must be perpendicular to section line
    make sure your section line is PERPENDICULAR to all your reference planes.
    I have only just figured this out. It has been driving me mental.
    Good luck .-)
    josephpeel likes this.
    March 13, 2012
    59
    05:51 AM
    Quote Originally Posted by jana.honkova View Post
    Good luck .-)
    good god this was driving me nuts, thank you for this post! another revit quirk that makes my blood boil...
    October 17, 2017
    1
    03:51 AM
    Thumbs up
    Good luck .-)
    HAHA... me too! Classic Revit!
    May 3, 2012
    1,401
    11:51 AM
    Ha..typical.
    I never use ref planes (Except in families), they clutter up the model.
    I dont even use sections any more, unless they are a detail to go on a sheet, for the same reason.
    Strangely (Because the industry is fixated on 2D?) they have tried hard to make 3D inaccessible in revit despite it being a 3D environment. But if you figure out what works you can model almost everything in 3D views and zip around in your model using the 'BX' auto 3D view.
    You can set your workplane to any existing surface in the 3D view and also use that to rotate things vertically.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,491
    02:51 AM
    Quote Originally Posted by josephpeel View Post
    Ha..typical.
    Hi Joseph, out of curiosity, what is a 'BX' auto 3D view??
    Gold Coast
    2,621
    07:51 PM
    Quote Originally Posted by Dave Jones View Post
    Works like the coins 3D section box, except you dont get to choose which 3D view you want to go to, or what the bounding box offset should be.
    Still a welcome addition to Revit though.
    Ps 'BX' is the default Revit keyboard shortcut
  1. how i can make offseted lines to refrence plane move along refrence plane?
    By ahmed_hassan in forum Architecture - Family Creation
    Last Post: October 17th, 2011, 04:40 PM
  2. Change work plane?
    By Steve Faust in forum Third party Add-Ins, API and R&D
    Last Post: August 18th, 2011, 06:10 PM
  3. How to work appropriately with Reference Planes and Reference Lines???
    By SkepticSon in forum Architecture and General Revit Questions
    Last Post: June 26th, 2011, 02:06 AM
  4. Rebar Perpendicular to work plane
    By Ali Akbar in forum Structure - General Questions
    Last Post: April 12th, 2011, 03:59 PM
  5. Window Cut Plane
    Last Post: January 13th, 2011, 07:08 PM
