Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By Munkholm
Thread: Architects Drawing Furniture/Curtains/Screens with Model Lines on the Floor
  1.    #1
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    268
    08:11 PM
    How does everyone deal with architects using model lines for things that should be elements? We have several architects that will draw curtains for patient areas or screens on the floor with model lines. This stops us from being able to see them in our reflected ceiling views.
    I've asked the architect if they could possible place these lines on a reference plane lifted off the floor so we could adjust our cut and see them. They said sure they'd do that no problem.
    They haven't.
    For now we've sided on having our cut plane go through or spaces for tagging rather than at the floor for the architects lines. If the architect doesn't want to change how they show these than I don't think there if much I can do about it.
    Also, I wish you could set a view range in here with out using linked view.
    Attached Thumbnails Attached Thumbnails Architects Drawing Furniture/Curtains/Screens with Model Lines on the Floor-arch-model-lines-01.png
  2.    #2
    Kingdom of Denmark
    4,230
    02:11 AM
    Personally I´d just go and punch the architect in the nose, and tell him/her to model it right.
    cellophane and tidalwave1 like this.
  3.    #3
    July 26, 2019
    DFW, Texas
    28
    07:11 PM
    Quote Originally Posted by Munkholm View Post
    You will find them over at the Civil Engineer's office hitting with a stick everyone who created a circular xref siteplan file in only 2/3 Civil 3D in "emulate acad" format. And not being able to find the clearly-labeled "export as AutoCAD" button. So that, along with the circular references, the 40-50,000 unshared custom linetypes with unshared shx files, the excrement files have around 3.2 million proxy objects in them as well, with embedded layer names (do we really need to share $0$sbind$0$bndry_surv0934t5834$0$no_print$0$S_ex_F ence_Mickey_Mouse-plot-only ?)
  1. Model not aligned with Architects. Can I just move it?
    By DCLowery in forum Structure - General Questions
    Last Post: June 10th, 2016, 05:16 PM
  2. can not show furniture on floor plan !!!!
    Last Post: January 21st, 2015, 09:19 PM
  3. Working in Architects model
    By JamesLawrence in forum MEP - General
    Last Post: January 20th, 2015, 03:26 PM
  4. Revit OpEd: Stage Curtains
    Last Post: October 16th, 2014, 03:45 AM
  5. Floor tiles over furniture
    By Helena Fields in forum Architecture and General Revit Questions
    Last Post: May 22nd, 2012, 02:34 PM
