Results 1 to 5 of 5
Thread: Daylight Calculation in Revit
  1.    #1
    Senior Member
    November 27, 2012
    599
    07:55 PM
    Can daylight calculations be done in revit? or is there a plug in that can be used.
    cheers
  2.    #2
    July 7, 2011
    Rotterdam, Holland
    1,228
    08:55 PM
    The people at https://xinaps.com/ should have something, but can't really find anything on their website anymore.
    I made myself various families and schedules to make it easier, but for me it is still a lot of manual work.
    [edit] looks like all info of the xinaps daylight calculation app is gone. Links to the Autodesk app store are dead and youtube video's removed. I guess that one is not there anymore
  3.    #3
    Coeur d Alene, ID
    4,783
    11:55 AM
    If you want to stick with Autodesk stuff....look into Insight https://www.autodesk.com/products/insight/overview
  4.    #4
    Senior Member
    November 27, 2012
    599
    07:55 PM
    was thinking about that, and also been looking at relux with the revit plugin.
    does the insight one work well? and correctly?
    cheers
  5.    #5
    Coeur d Alene, ID
    4,783
    11:55 AM
    I've never had to use it. Although I have a project right now that I probably could test it out if I wanted.
  1. Daylight Savings Time
    By pivoarch in forum Forum Suggestions and Feedback
    Last Post: November 18th, 2014, 09:01 PM
  2. Revit Kid: LEED Daylight Analysis Using Revit
    By The Revit Kid in forum Blog Feeds
    Last Post: December 27th, 2013, 01:16 PM
  3. 0 daylight portal
    By hanaa in forum Architecture and General Revit Questions
    Last Post: November 25th, 2013, 02:56 PM
  4. Daylight portals
    By bayswater in forum Architecture and General Revit Questions
    Last Post: August 25th, 2011, 12:48 PM
  5. Daylight Savings Time
    By JTB in forum Architecture and General Revit Questions
    Last Post: May 30th, 2011, 11:46 PM
