Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Like Tree3Likes
Thread: Facebased Family
  1. #11
    Senior Member
    November 27, 2012
    599
    08:45 AM
    this does not work, as I mentioned in my first post - this only works if its a wall based family first.
  2. #12
    10,205
    02:45 AM
    Face based will cause problems in Groups even if the wall is in the group.
    It will work fine for the first object hosted to a walls face. It will break on the second object hosted to a walls face.
    Robin Deurloo likes this.
  3. #13
    July 7, 2011
    Rotterdam, Holland
    1,235
    09:45 AM
    Quote Originally Posted by nick_h View Post
    here you go.
    You can remove the face from the family in the way I posted above, but you can not set the offset of the family when placed in your project. So this will not work. You can of course load that family (when it is un-hosted with that trick) into a new unhosted family that does have the offset parameter and use that in your project.
  4. #14
    July 7, 2011
    Rotterdam, Holland
    1,235
    09:45 AM
    Interesting, have never really used hosted families, so did not figure out when it all goes bad.
    Good to know.
  5. #15
    December 21, 2010
    Phoenix, AZ
    2,610
    12:45 AM
    My reply was for Robin.
  1. 2d Family vs 3d Family; Multi-Family Residential
    By deepblue02101996 in forum Architecture and General Revit Questions
    Last Post: April 10th, 2019, 06:47 PM
  2. Replies: 0
    Last Post: March 27th, 2016, 07:18 AM
  3. NewFamilyInstance facebased copy to Element wrong Reference
    By DevDemon in forum Third party Add-Ins, API and R&D
    Last Post: June 12th, 2015, 06:08 AM
  4. Facebased family symbol won't show.
    By GabrielBlack in forum MEP - Family Creation
    Last Post: January 14th, 2013, 09:24 PM
  5. facebased structural connection and hidden lines issue
    By jh75 in forum Structure - Family Creation
    Last Post: August 16th, 2012, 03:16 PM
