Results 1 to 3 of 3
Thread: Can not delete insulation off pipework
  1.    #1
    April 25, 2014
    Elllesmere Port, Cheshire, UK
    97
    01:21 AM
    Hi
    i have taken over a job which has all the pipework with insulation on, I need to work and make changes, I have removed the insulation, but it is still there
    even though when I select the pipe, I have option to add insulation to it, why is it still there? I tried on VG to untick Pipe insulation, but it is still showing, I cant select it to hide, remove etc. any ideas?
    regards
  2.    #2
    Senior Member
    June 14, 2011
    CT, USA
    554
    09:21 PM
    Insulation can be buggy but without an example file my guess is that it is not insulation.
  3.    #3
    Member TFuller's Avatar
    March 7, 2014
    Evansville, IN
    354
    08:21 PM
    Insulation also has its own phasing.
  1. Can not delete Duct Insulation
    By fifthtexas in forum MEP - General
    Last Post: September 22nd, 2017, 10:45 AM
  2. Revit Pipework - How far do we take it
    By domsib in forum MEP - General
    Last Post: July 14th, 2014, 09:08 AM
  3. Connections Pipework
    Last Post: June 9th, 2014, 02:26 PM
  4. Scheduels for all pipework
    By Madmax8181 in forum MEP - General
    Last Post: December 5th, 2013, 09:02 PM
  5. Building Coder: Pipe Insulation and Insulation Material
    Last Post: May 24th, 2012, 09:15 AM
