Results 1 to 6 of 6
Thread: Duct Hidden Line Style Not Working In Parent View
  1.    #1
    Member koolair's Avatar
    July 31, 2014
    246
    08:28 PM
    Hi Guys,
    My duct parent view won't display hidden line style. But the dependent views covering a smaller area do. Any suggestions?
    Are there too many elements on the screen? This is weird. Hope someone can help.
    ETA: Ditto for my piping views. Parent views won't display hidden lines, pipe centerlines but the dependent views are a-ok.
  2.    #2
    Senior Member
    June 14, 2011
    CT, USA
    554
    08:28 PM
    Are you using different scales? The parent view scale my be too small to show the line pattern.
  3.    #3
    July 31, 2014
    246
    08:28 PM
    The parent and dependent have to be the same scale. I checked both 1:50 and 1:100. Same problem dependents are good but the parent is not. Using revit 2018.
    Sent from my SM-N950W using Tapatalk
  4.    #4
    Senior Member
    June 14, 2011
    CT, USA
    554
    08:28 PM
    Okay, that was my first guess. I'm not going to keep guessing. Please post all view settings including the properties for the view and the V/G view template if you are using one. Alternatively, you could them yourself for any differences.
  5.    #5
    July 31, 2014
    246
    08:28 PM
    Quote Originally Posted by RobDraw View Post
    Sure, as soon as I get a chance. One thing I should mention is my underground parent view is perfect shows all hidden line types everything but when I copy that view template, adjust filters to show other systems like duct and flat piping, apply it to another floor, hidden line types don't show up. Bizarre will get back to you
  6.    #6
    Mr. Revit OpEd
    2,830
    05:28 PM
    Quote Originally Posted by koolair
    ...but when I copy that view template, adjust filters to show other systems like duct and flat piping, apply it to another floor, hidden line types don't show up. Bizarre will get back to you...
    Sounds like view range needs are different for these levels.
  1. Colour in Hidden Line Visual Style
    By JuJitsoup in forum Architecture and General Revit Questions
    Last Post: June 27th, 2018, 10:30 AM
  2. Edges drop out with Hidden Line Visual Style
    By threecats in forum Architecture and General Revit Questions
    Last Post: January 15th, 2016, 07:49 PM
  3. Hidden line view. Hidden lines showing.
    By redmonki in forum Architecture and General Revit Questions
    Last Post: July 27th, 2013, 09:12 AM
  4. transparent materials in hidden line visual style?
    By lost again again in forum Architecture and General Revit Questions
    Last Post: December 8th, 2012, 07:01 AM
  5. Show Hidden Line - Not working the way I want it to
    By Hilife in forum Architecture and General Revit Questions
    Last Post: November 19th, 2012, 05:59 PM
