Results 1 to 3 of 3
Thread: Pipe tag leader take off
  1.    #1
    Lurker
    February 28, 2019
    1
    04:45 PM
    Hi There,
    Probably a simple answer that I just can't seem to find on the internet. I have a pipe tag that is 3 lines and cannot seem to figure out how to change where the leader position takes off from the text. It is presently set to the center, however I would like it to be at the top.
    Many thanks!
  2.    #2
    December 29, 2014
    Calgary, Canada
    178
    06:45 PM
    the leader always only goes to the centre of whatever you have in your tag. To make it look like it's coming off the top, you will need to create "invisible" items (like labels that use parameters you never use) that make the "top" of your tag in the centre.
  3.    #3
    Senior Member Alex Page's Avatar
    Wellington, New Zealand
    630
    01:45 PM
    Like evan says:
    We put a vertical invisible line in our tag, bigger than the labels, that is centered on where we want the leader position to lead from
  1. Can a pipe fitting be converted into a pipe accessory?
    By andyrh1982 in forum MEP - General
    Last Post: June 13th, 2018, 12:01 PM
  2. Pipe-in-pipe, containment pipe, double-wall pipe ?
    By gerryblake in forum MEP - General
    Last Post: June 14th, 2017, 04:14 PM
  3. pipe fittings and pipe valves size adjustment
    By Darius in forum Dynamo BIM
    Last Post: May 20th, 2016, 01:19 PM
  4. Pipe Settings dialog vs Pipe Systems
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: December 7th, 2015, 09:00 PM
  5. Square/Rectangular Pipe: Is there a System Pipe this shape?
    By samz1 in forum Architecture and General Revit Questions
    Last Post: March 6th, 2014, 12:22 AM
