Results 1 to 1 of 1
Thread: Store Designline elements creating empty .rif file?
  1.    #1
    Lurker
    February 25, 2019
    1
    06:00 PM
    So I'm at a new company and we received a revit model that we need to export into CADMep. At my old company we would just select the piping and store designline elements and then OUT and then map the components as needed. Now when I try, it gives this error "An internal error occurred during export.
    Can't get system elements."
    If I convert the pipe with "Design to Fabrication" first it will export the .rif file but it is only 1kb in size and when I import into CADMep using process run the dialog box is empty (see attachment). I am using 2019 AutocadMep/FabricationMep and 2019 Revit. I have all 2019 Autodesk products installed currently.
    Attached Thumbnails Attached Thumbnails Store Designline elements creating empty .rif file?-map-dialog-empty.jpg
  1. what information do yu store in the keynote file
    By jh75 in forum Architecture and General Revit Questions
    Last Post: July 15th, 2017, 05:26 AM
  2. roombounding elements in a IFC file
    By andreas2 in forum Architecture and General Revit Questions
    Last Post: April 27th, 2017, 08:09 AM
  3. Creating family - parameter that allows to set a number of elements
    By tomas92 in forum Architecture and General Revit Questions
    Last Post: November 14th, 2013, 02:44 AM
  4. Creating Walls with elements at various heights
    By Lox in forum Architecture and General Revit Questions
    Last Post: July 26th, 2013, 06:46 AM
  5. Replies: 0
    Last Post: September 18th, 2012, 04:15 AM
