Results 1 to 4 of 4
Thread: Hide compound ceiling pattern not ACT?
    February 6, 2015
    84
    10:37 AM
    Hi all, as the title says, I'd like to hide the compound ceiling pattern, but not the ACT ceiling pattern. How do I go about doing that? I know I've done this before. I just can't remember how.
    Thanks!
    Coeur d Alene, ID
    4,737
    03:37 AM
    Filters
    February 6, 2015
    84
    10:37 AM
    lol thank you for the concise answer. I thought about filters, but thought I was able to acomplish it before without using filters...perhaps it was something else I did.
    Anyway, I used the type mark of the ceiling in my filter, and that worked. Not sure if there is a more consistent parameter I can use that will work across different architectural models, but it worked for this client.
    Thanks!
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,963
    05:37 AM
    Maybe you changed the Material's Surface Pattern to <none> ?
  1. Creating Ceiling Grid Pattern
    By dmhokie in forum Architecture and General Revit Questions
    Last Post: February 22nd, 2019, 07:03 PM
  2. Hide the 'Cut material pattern' of terrain
    By MARIA1993 in forum Architecture and General Revit Questions
    Last Post: September 13th, 2018, 08:16 AM
  3. Ceiling surface pattern alignment on sloped ceiling?
    By Mike Ferrell in forum Architecture and General Revit Questions
    Last Post: June 17th, 2014, 02:55 PM
  4. Hide Blockwork Cut Pattern at Certain Scale
    By dfallow in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2014, 12:45 PM
  5. Fliters : Pattern overrides on ceilings - not displaying compound ceiling tile lines
    By brinxb in forum Architecture and General Revit Questions
    Last Post: March 26th, 2013, 11:24 PM
