Results 1 to 2 of 2
Thread: MEP Fabrication Parts 2D Export
    Member TFuller's Avatar
    March 7, 2014
    Evansville, IN
    361
    06:56 AM
    Exclamation MEP Fabrication Parts 2D Export
    FYI...
    When exporting a plan view for 2D DWG, I receive some interesting behavior regarding MEP Fabrication Parts.
    If the visual style in Revit is set to Hidden Line, the exported geometry blocks (pipe, duct and associated insulation/liner) will be placed on layer A-DETL-THIN. Turning off this layer allows the line-work within the block to display correctly.
    Flex Duct is not affected. Air Terminals are not affected. Just FAB Parts.
    Attached Thumbnails Attached Thumbnails MEP Fabrication Parts 2D Export-detl-thin-.jpg   MEP Fabrication Parts 2D Export-detl-thin-off.jpg
    March 7, 2014
    Evansville, IN
    361
    06:56 AM
    The A-DETL-THIN layer is set by whatever line-type your mechanical settings points to in regards to drawing hidden line detail. Mine was set to thin lines (which of course is wrong and I have corrected that).
    Additionally, it would appear that blocks for straights and some fittings (along with their respective liner/insulation) are on the hidden line layer, but other fittings and insulation/liner are not.
    Still no good path to resolve this issue... No amount of clever lisp routines can fix Revit exporting the blocks to mismatched layers.
  1. Fabrication Parts in Revit 2019
    By NAILZ7 in forum MEP - General
    Last Post: March 11th, 2019, 09:09 PM
  2. Ductwork System Parts V Fabrication Parts
    By Sean_Rooney in forum MEP - General
    Last Post: January 3rd, 2019, 02:13 PM
  3. Fabrication Parts Revit 2018.3
    By nick_h in forum MEP - General
    Last Post: June 21st, 2018, 04:25 PM
  4. Fabrication Parts - Connector Change
    By MChilds in forum MEP - General
    Last Post: May 24th, 2017, 08:30 AM
  5. Revit 2016 Fabrication parts
    By lukemcgary in forum MEP - General
    Last Post: July 11th, 2016, 06:16 PM
Tags for this Thread
