Results 1 to 6 of 6
Thread: Single Line pipe (Course Detail) - Changing fill options
    February 8, 2019
    Willenhall, UK
    9
    12:40 PM
    Can the fill option be changed for single line piping (course detail) when rising/falling
    I wish to keep the same colour for the rise/fall of the pipe, in this instance green. There appears to be no option to change in family editor
    The standard for this fill is Black, even when overriding the element I cannot change to green.
    Attached Thumbnails Attached Thumbnails Single Line pipe (Course Detail) - Changing fill options-single-line-pipe-rise-filled.png
    Senior Member
    June 14, 2011
    CT, USA
    561
    08:40 AM
    Have you checked object styles?
    February 8, 2019
    Willenhall, UK
    9
    12:40 PM
    The object styles have been checked and changed to a different colour (Cyan). The problem is if I change the colour all of my pipe rise/falls change with it.
    Ideally i'd like to have the same colour as each individual system, Is there any way I can individually change the object style for each of my systems as the image below?
    If all else fails i'll have to each rise/fall with 'outline-no fill'
    Thanks
    Attached Thumbnails Attached Thumbnails Single Line pipe (Course Detail) - Changing fill options-rise-fall-issue.png
    Senior Member
    June 14, 2011
    CT, USA
    561
    08:40 AM
    I thought you said the standard is black.
    How are you assigning colors to the systems?
    February 8, 2019
    Willenhall, UK
    9
    12:40 PM
    I can change the system colour in >Project Browser > Families > Piping Systems > 'Select Family' > Graphic Override
    Even when overriding the colour for a system, the standard rise/drop symbol for all pipes in single line is black. I can only change the rise/drop colour through your advice of visiting the object styles, but the object styles override settings change all rise/drops in the project and not individual systems.
    I've scoured the internet and I don't think it can be changed for each system, just a universal colour through the object styles
    Senior Member
    June 14, 2011
    CT, USA
    561
    08:40 AM
    It appears that you are correct.
  1. Replies: 6
    Last Post: January 30th, 2019, 07:04 PM
  2. Double line and single line pipes based on size?
    By Theophilous in forum MEP - General
    Last Post: July 6th, 2018, 05:04 PM
  3. help to display pipe with with only single line
    By trang_chau in forum MEP - Family Creation
    Last Post: April 18th, 2016, 02:13 AM
  4. Changing Detail level of a single object?
    By RsqPrincess in forum Structure - General Questions
    Last Post: April 24th, 2013, 01:16 PM
  5. Why when i draw pipe it shows single line ??!
    By ahmed_hassan in forum MEP - General
    Last Post: August 15th, 2012, 04:10 PM
