Results 1 to 6 of 6
Thread: Viewport - Not able to crop annotation
    February 8, 2019
    Willenhall, UK
    9
    11:32 AM
    I am not able to crop annotation box (Yellow) to suit the crop of my view (Red).
    This results in a poor view which includes unwanted items , surely there is a way to crop the annotation to suit the rotation of the building?
    Rotating the viewport 25degrees to portrait does work, however it's out of the question that we rotate to suit, we need the true angle of the building (25degrees).
    Any help would be great.
    Attached Thumbnails Attached Thumbnails Viewport - Not able to crop annotation-capture.png
    Member koolair's Avatar
    July 31, 2014
    263
    07:32 AM
    Quote Originally Posted by tom recarb View Post
    Create a scope box, name it. Rotate it 25 degrees. Then associate your view to that scope box name (in the view's properties palette)
    Sent from my SM-N950W using Tapatalk
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,965
    06:32 AM
    In the meantime, please go vote up this Revit Idea
    https://forums.autodesk.com/t5/revit.../idi-p/6432361
    February 8, 2019
    Willenhall, UK
    9
    11:32 AM
    The scope box has cleaned all the grid lines and annotation up perfectly!!
    Problem is - After rotating the scope box 25degrees to match the building and then applying to the view, it goes back to a 90degree angle. And I cannot then rotate the viewport.
    This is frustrating because it's cleaned all the stuff I didn't need, then reverted back to the 90degree angle. Any ideas (any ideas from the pics below)
    Attached Thumbnails Attached Thumbnails Viewport - Not able to crop annotation-scope-box-set-up-1-rotate-25.png   Viewport - Not able to crop annotation-scope-box-applying-view.png
    Gold Coast
    2,609
    09:32 PM
    This is a limitation in Revit which gets even more annoying if you ever go down the by linked view route. Follow the link Dave posted and make some noise
    June 21, 2012
    Tours, France
    947
    01:32 PM
    ... Follow the link Dave posted and make some noise..
    Voted!!
  1. section mark still show up way beyond crop region and annotation crop
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: November 5th, 2017, 05:42 PM
  2. Annotation Crop and Matchlines
    Last Post: January 19th, 2017, 06:52 PM
  3. Annotation Crop Extents
    Last Post: June 13th, 2014, 12:03 PM
  4. irregular Annotation crop shape
    By clickster in forum Architecture and General Revit Questions
    Last Post: June 11th, 2014, 07:44 AM
  5. Crop a viewport
    By dospuntos in forum Architecture and General Revit Questions
    Last Post: October 23rd, 2012, 01:03 PM
