Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By cellophane
Thread: Viewport cropping - Not cropping correctly
    February 8, 2019
    Willenhall, UK
    9
    09:47 AM
    (First Post)
    I'm having a slight issue with view cropping (I assume).
    I have created a co-ordination view of all MEP services per floor, then created dependent views of each room this co-ord view.
    Once I have cropped to a room it looks great, to size. Then when bringing into my sheet another black border comes around the view...
    From the attached images can anyone tell me how to reduce/remove this black "border" as it has a impact on when plotting. Any help would be great
    Attached Thumbnails Attached Thumbnails Viewport cropping - Not cropping correctly-ok-view.jpg   Viewport cropping - Not cropping correctly-black-border-view.jpg
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,051
    05:47 AM
    What are your printer settings? In the dialog you have the ability to print Centered or Offset from Corner, and Fit to Page or Zoom.
    Attached Thumbnails Attached Thumbnails Viewport cropping - Not cropping correctly-printsettings.png
    tom recarb likes this.
    Coeur d Alene, ID
    4,634
    02:47 AM
    Does it not go away when you click outside of the box?
    September 19, 2017
    Seattle, WA
    26
    02:47 AM
    The black box is the extent of the viewport, and it should be there. It being too big, however, is an issue I've come across, especially when working with linked models. What I've typically found is that the 3D extent of some element (be it grids, reference planes, invisible line tricksssss) lies very far outside of the crop region. I have never been able to reproduce the error, and sometimes is just one floor plan, and sometimes the whole building is doing it.
    I'd suggest you turn the linked grids, levels, and reference planes off in that view, and see where that gets you. As for printing, make sure you have it set up properly like Chad said. I don't think I've ever seen this issue affect printing before.
    February 8, 2019
    Willenhall, UK
    9
    09:47 AM
    I've changed the settings to - Fit to Page & Centered and this seems to work. Many Thanks
    February 8, 2019
    Willenhall, UK
    9
    09:47 AM
    It does go away when I click away from the viewport. But it didn't fix the issue, I think it may have been the post above regarding the print settings. Thanks for the post
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,886
    04:47 AM
    I assume you've already checked the Annotation Crop size?
    February 8, 2019
    Willenhall, UK
    9
    09:47 AM
    Yes crop size all checked. I think the issue was with my printer settings posted by 'Cellophane'.
    Regarding the black box around the viewport, I think it has something to do with my building layout. The East wing is set at a 25degree angle, so I rotated the viewport 25degrees to compensate, thus making the gridlines etc go off sorts.
    I will post another thread regarding this (another problem I have)
    Thanks all
  1. Cropping renders in Lumion
    By piper76 in forum Rendering and Gallery
    Last Post: March 22nd, 2018, 07:35 AM
  2. Cropping A Legend
    By Chris.kershaw in forum MEP - General
    Last Post: August 28th, 2015, 02:15 PM
  3. Cropping a linked revit file
    By mseese in forum Architecture and General Revit Questions
    Last Post: January 13th, 2014, 07:00 PM
  4. viewport title
    By minuj23 in forum Structure - General Questions
    Last Post: July 9th, 2013, 11:58 PM
  5. DWF not linking correctly
    By TonySteele in forum MEP - General
    Last Post: May 30th, 2013, 05:16 PM
