Results 1 to 4 of 4
Thread: Takeoff position
    Lurker
    January 11, 2019
    1
    02:07 PM
    Takeoff position
    How do I control duct takeoff position?
    Sometimes it takes off from side of the duct, while other times it takes off from top or bottom - i don't know why it happens and how to control it.
    January 17, 2011
    1,978
    11:07 AM
    I keep myself in a plan view always when running ductwork. I use the "Inherit Elevation" tool to make sure the duct runouts are consistent elevations as the main duct branch.
    -TZ
    January 19, 2019
    1
    04:07 PM
    Which side of a duct you will connect a flex duct depends on the offset while sketching a flex duct. So, to connect flex duct to the side of the duct you need to setup the same offset of the flex pipe as the duct is. But in my opinion it is better to place tees and after that to sketch flex duct between tee and air terminal.
    Maike
    December 29, 2014
    Calgary, Canada
    178
    10:07 AM
    Similar to what maiko said, I always draw a short segment (~300mm) of straight hard duct before drawing the flex duct. In my case we use takeoffs rather than tees, and we use a damper-less takeoff which forces people to put the damper in the short run of duct.
  1. Material Takeoff
    By robledojuan7 in forum Architecture and General Revit Questions
    Last Post: February 9th, 2016, 03:56 PM
  2. Material Takeoff
    By gdoherty0102 in forum Structure - General Questions
    Last Post: September 25th, 2013, 06:39 PM
  3. Takeoff Accuracy
    By Cambraceres in forum Architecture and General Revit Questions
    Last Post: May 13th, 2013, 10:58 PM
  4. Material Takeoff
    By anjali in forum Architecture and General Revit Questions
    Last Post: July 30th, 2012, 01:37 PM
  5. Glass Takeoff
    By nelsner9494 in forum Architecture and General Revit Questions
    Last Post: December 16th, 2011, 06:00 PM
