Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By RobDraw
Thread: Duct Fitting Breaks Air Flow
  1.    #1
    Senior Member
    June 14, 2011
    CT, USA
    527
    03:12 AM
    I'm missing something simple with this family that I built. I've tried a couple different ways, even edited an OOTB family that does work. When I connect a duct with airflow to this the airflow gets set to 0.
    Attached Files Attached Files
  2.    #2
    December 29, 2014
    Calgary, Canada
    174
    01:12 AM
    Did you try changing what the part type is? Perhaps try setting it as a wye or pants or multiport fitting. Also, IIRC, fittings like to have the primary connector on the left, so you could try rotating the family so that is true.
  3.    #3
    Senior Member
    June 14, 2011
    CT, USA
    527
    03:12 AM
    The solution was to remake the connectors. The family was originally categorized as mechanical equipment. After putting it into the project I realized that wasn't going to work and changed it to a fitting. I guess the category of the family has a hidden effect on the properties of the connectors.
    evan.dodds likes this.
  1. Replies: 3
    Last Post: July 28th, 2018, 02:46 AM
  2. Duct Fitting Area
    By lukemcgary in forum MEP - Family Creation
    Last Post: July 18th, 2018, 09:23 AM
  3. Displaying of duct connected to the duct fitting branch 45°
    By MiaEliska in forum MEP - Family Creation
    Last Post: February 22nd, 2016, 09:19 AM
  4. Rogue Sanitary Fitting Cold Water Flow Rates
    By drowles in forum MEP - General
    Last Post: July 16th, 2015, 05:10 PM
  5. flow in the main duct
    By lelion in forum MEP - General
    Last Post: July 17th, 2013, 08:17 AM
