Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Robert Roffe
Thread: hide part of a pipe
  1.    #1
    Member philsogood's Avatar
    June 30, 2016
    Lyon - France
    110
    06:10 AM
    hide part of a pipe
    hello
    i'd like to hide a part of a pipe (the part which is in the red rectangle) because i'd like to see what is beyond the pipe
    in this example the pipe is short but it could be useful for a bigger pipe/duct
    is it possible?
    Phil
  2.    #2
    Member TFuller's Avatar
    March 7, 2014
    Evansville, IN
    341
    11:10 PM
    I think you would need to hide the pipe and use a detail component to draw the stubs and break lines from the elbow and valve.
  3.    #3
    September 19, 2017
    Seattle, WA
    13
    09:10 PM
    A Detail Item is the way I've done it. It's such a pain. Plus, the system color override doesn't get applied without a carefully curated set of filters. I wish there was an integrated way to apply breaks to objects quickly that doesn't fall apart when you inevitably have move them.
  4.    #4
    May 3, 2012
    1,381
    06:10 AM
    How about a Union with the pipe cut off detail item in it. Then you could Split the pipe where you want and hide the bit in between.
    The Unions would move with the pipe, but they may disappear if you resize the pipe (because both sides are the same size).
    Or a pipe Tag should move with the pipe too, but not as reliably.
  5.    #5
    September 19, 2017
    Seattle, WA
    13
    09:10 PM
    I could see that working in one view. But then you're stuck with a union that looks very odd in any view that you don't want to hide the pipe in, unless you fiddle with visibility parameters. And you're flirting with incorrect length measurements and fitting counts (if you're using them). Pipe Tags would be an even bigger pain because you'd end up with hundred of types for each size and scale.
    In my mind, 2D detail items are supposed to handle these one-off conditions. And for as often as I have to do something like this, keeping in mind the need to check a 2D element isn't any more effort than making sure the routing preferences don't override an interloping fitting. Or just eliminate the need to break the pipe at all by cutting a section. Either will prompt the same amount of questions from the field.
    josephpeel likes this.
  6.    #6
    June 30, 2016
    Lyon - France
    110
    06:10 AM
    Robert,
    I think you're right.
    I've thought to insert union on my pipe/duct but I knew that others views I would see the union and I didn't like this idea even if the union is very small, I would still have a line for the union...*
    I don't see how to use 2D detail for that...*
    But adding a detail nearly three view to see beyond the pipe seems to be a great idea
    Thanks for your answers.*
    Phil
  7.    #7
    Member kubsix's Avatar
    March 31, 2011
    Quad Cities, Illinois
    279
    11:10 PM
    It appears the view is set to the Coordination discipline. Any reason you can’t use Mechanical discipline with hidden linestyle? Doesn’t answer the question but would show more of the valve and components beyond if that is what you’re trying to achieve.
  8.    #8
    June 30, 2016
    Lyon - France
    110
    06:10 AM
    hi John
    you're definetly right
    we have some such habit to use template or views ever made that we forgot the basics...
    need to focus on the basics, to have distance with our use of the software
    many thanks to all
    Phil
  9.    #9
    New Member Foreex's Avatar
    January 14, 2019
    1
    05:10 AM
    Thanks! It helps me.
  10.    #10
    New Member fhaller's Avatar
    January 10, 2019
    Atlanta
    2
    12:10 AM
    Yes you can hide the pipe.
    1. select the pipe
    2. go to the Sunglasses Icon (see image below) on the bottom bar and hover over it. it should said "Temporary Hide/ Isolate"
    3. Click the sunglasses icon
    4. drop down menu will appear, pick the bottom one which is "Hide Element" This will just hide the pipe. if you want to hide all of the pipe in this system, then click on "Hide Category"
    5. it should now disappear.
    Note, once you have made changes to whatever is below the pipe be sure to go back to the sunglasses icon and click "Reset Temporary Hide/Isolate". if you don't and collaborate and snyc with central, you have now erased this pipe for all users. ENSURE YOU RESET IT ONCE YOU ARE DONE.
    Attached Thumbnails Attached Thumbnails hide part of a pipe-schedule-capture.jpg
  1. Pipe-in-pipe, containment pipe, double-wall pipe ?
    By gerryblake in forum MEP - General
    Last Post: June 14th, 2017, 04:14 PM
  2. Show Sleeves, Hide Valves & Other Pipe Accessories
    By koolair in forum MEP - General
    Last Post: May 12th, 2017, 12:19 PM
  3. Here's part 10 of my 10 part series on Creating Loadable Revit Families:
    By MichaelLV in forum Architecture - Family Creation
    Last Post: April 14th, 2016, 07:45 PM
  4. Pipe and duct fittings not part of systems
    By JamesLawrence in forum MEP - General
    Last Post: August 27th, 2013, 02:54 PM
  5. Hide part of underlay drawing
    By gpktm in forum Architecture and General Revit Questions
    Last Post: November 13th, 2012, 03:48 PM
Tags for this Thread
