Results 1 to 2 of 2
Thread: Sleeving
    Member koolair's Avatar
    July 31, 2014
    263
    07:36 AM
    Sleeving
    On the last project I did, my sleeving was set up to display the following from linked models:
    Beams and drop panels (structural framing) on level below.
    Room layouts on current level.
    Plumbing fixtures.
    Hidden were the following:
    Ceilings.
    Devices.
    All MEP.
    On my new project, I wasn't able to transfer view view templates, so I'm setting it up manually. I have all the same VG settings except that the walls on the floor below are showing. This might be due to the fact my view range bottom is -1000mm (cut plane is 2000) but if I set the bottom to 0 as I did on my last project, I don't get to see all the framing. Seeing the walls below would be fine if I could somehow shade the walls on the current level to differentiate, but it's not working.
    Any hints?
    Discipline = coordination
    Linked models = underlay
    I tried setting the discipline to structural but this hides all stud walls amongst other undesirable effects.
    Completely stumped.
    Orlando, FL, USA
    3,098
    07:36 AM
    Sounds that it would be easier to set this up with the view template from the previous project. What happened when you tried to transfer that view template?
