Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By tzframpton
Thread: Duct line types / visibility settings
    November 1, 2018
    Finland
    4
    04:05 AM
    Hi
    I'm trying to make Revit duct plans look good as AutoCAD ones.
    Are these "rules" possible? Far as I know, first three are bossible, but not at the same time.
    1. Duct edge line type is automatically selected by elevation.
    2. Center line is user definable (type and width).
    3. Hidden parts are correctly displayed with hidden lines.
    4. In insulated ducts only outer line is displayed. And its line type is displayed correctly by elevation.
    Picture from AutoCAD/MagiCAD shows what I want it to look like.
    Attached Thumbnails Attached Thumbnails Duct line types / visibility settings-mcad.jpg
    Member koolair's Avatar
    July 31, 2014
    217
    09:05 PM
    If you set your visual style to "hidden" and turn on centerlines for your duct and duct fitting categories you will get a centerline on all round duct but not rectangular. You can specify what style of centerline you want, for example, I picked Center 1/4".
    January 17, 2011
    1,962
    08:05 PM
    You can definitely get to what you're wanting to achieve although there will be some areas you'll have to live with it not being an exact replica.
    -TZ
    koolair likes this.
    November 1, 2018
    Finland
    4
    04:05 AM
    Quote Originally Posted by koolair View Post
    But that doesn't work with duct linetype elevation filters on. Filters override centerline type setting.
  1. Duct System, fittings and settings
    By BasLn in forum MEP - General
    Last Post: March 6th, 2018, 01:48 PM
  2. Duct Tag Types
    By RobDraw in forum MEP - General
    Last Post: July 6th, 2017, 11:21 PM
  3. Duct Types in a Legend
    By mkicher in forum MEP - General
    Last Post: November 19th, 2013, 05:46 PM
  4. Duct Conversion Settings
    By chengyuw in forum MEP - General
    Last Post: June 6th, 2012, 07:21 PM
  5. 3D visibility settings
    By Will P. in forum Architecture and General Revit Questions
    Last Post: June 22nd, 2011, 05:38 PM
