Results 1 to 3 of 3
Thread: Revt M.E.P. Fire damper color shading issue
    Lurker
    October 9, 2018
    1
    01:48 PM
    Hi not sure if you can see these images big enough but we are having a issue with the fire dampers.. the triangle symbols shading not showing completely solid black.. some are half tone and all the color line weights are the same for each one. see the variations in the triangles shading.. How would I change the shading to match the darkest one in the template or settings? They are not set on halftone.. the duct line weight matches all the other s/a e/a r/a and the shading is light?? Please respond.
    Attached Thumbnails Attached Thumbnails Revt M.E.P. Fire damper color shading issue-black-white.png   Revt M.E.P. Fire damper color shading issue-color.png
    October 25, 2018
    2
    11:18 PM
    can you share that file so i can check what is the issue
    January 22, 2013
    26
    05:48 PM
    As mentioned above it will be easier to find the issue if you could share the model or at least the fire damper family.
    Looking at the images you provided it looks like that dampers at similar elevations look the same.
    So you either have a filter that effecting the display of FDs or the family been put together in that way.
    Have you tried playing with view range to see if anything change?
  1. why shading material color gets overridden by surface color
    By brankulo in forum Architecture and General Revit Questions
    Last Post: April 25th, 2018, 12:20 AM
  2. Automatically assigning a fire rating to a door when placed within fire rated wall
    By BEATl in forum Architecture and General Revit Questions
    Last Post: November 1st, 2016, 09:32 PM
  3. Ductwork Shading
    By shannononeal in forum MEP - General
    Last Post: February 3rd, 2016, 09:56 PM
  4. Damper Not Completely Visible
    Last Post: January 20th, 2016, 04:11 PM
  5. Getting rid of Revt Server in File Dialog 'Places'
    Last Post: November 11th, 2014, 11:06 AM
