Results 1 to 2 of 2
Thread: Weigth of the pipe .
    June 5, 2015
    88
    01:02 PM
    We are drawing a job that the requirement is that we need to post the weight of the pipe. We have a schedule that shows
    pipe cut pieces and how can I create a formula inside schedule showing the weigth of that pipe. Any one have any idea
    how can I create that formula? or a website that shows formulas samples?
    January 27, 2017
    North Dakota
    116
    11:02 AM
    Did you do a google search? It is pretty easy to add a Calculated Parameter to your schedule.
  1. Can a pipe fitting be converted into a pipe accessory?
    By andyrh1982 in forum MEP - General
    Last Post: June 13th, 2018, 12:01 PM
  2. Pipe-in-pipe, containment pipe, double-wall pipe ?
    By gerryblake in forum MEP - General
    Last Post: June 14th, 2017, 04:14 PM
  3. pipe fittings and pipe valves size adjustment
    By Darius in forum Dynamo BIM
    Last Post: May 20th, 2016, 01:19 PM
  4. Pipe Settings dialog vs Pipe Systems
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: December 7th, 2015, 09:00 PM
  5. Square/Rectangular Pipe: Is there a System Pipe this shape?
    By samz1 in forum Architecture and General Revit Questions
    Last Post: March 6th, 2014, 12:22 AM
Tags for this Thread
