Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By ckilger12
Thread: Faced Hosted Family Changing Elevation with Base Offset of Wall
    February 3, 2017
    3
    01:42 PM
    I have various Face Hosted electrical/fire alarm families and in particular case the architect has changed the Base Offset of the hosting wall to -10'-0" to show walls for a crawlspace below. The family in this case is changing elevation following that -10' Base offset. So it was originally placed at 4'-0" elevation...After this architectural model update which changes the base offset of this wall in question the families move to -6'-0". All levels in host model have not changed and are correct.
    Attached Thumbnails Attached Thumbnails Faced Hosted Family Changing Elevation with Base Offset of Wall-base-offset.png   Faced Hosted Family Changing Elevation with Base Offset of Wall-elevation.png
    December 21, 2010
    Phoenix, AZ
    2,470
    10:42 AM
    I assume you’re asking if that’s supposed to happen? Yes, it is. Does it make sense? Yes, and no. Depends on what you’re doing.
    There’s a general move away from face based families for this and other reasons.
    An unhosted family wouldn’t have this issue but you have to track its location relative to changes in the wall. Pick your poison.
    February 3, 2017
    3
    01:42 PM
    that's good to know. myself and a few others were always under the impression that the elevation of the hosted family was based off the actual level associated not the connected point of the wall. Thanks.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,031
    12:42 PM
    What causes that change? I've seen it in the past and it's always bugged me, but when trying to replicate it just now (2019.0.1) I couldn't get it to move the family when changing the wall base offset unless I change the actual base level.
    https://www.screencast.com/t/GWlq4eDZ5
    February 3, 2017
    3
    01:42 PM
    Fix with Revit 2019 maybe, my example was 2018.3........one of the guys in office has a saying "It is Revit just Reviting"
    ThatBIMGuy likes this.
  1. Complex Wall issues with wall based elements base offset 0
    By Hype in forum Architecture and General Revit Questions
    Last Post: March 30th, 2017, 01:37 PM
  2. Wall base offset issue with foundation attachment. Any advice?
    By jmthomas in forum Structure - General Questions
    Last Post: August 5th, 2016, 06:17 PM
  3. Nested wall hosted family to align with top/bottom of wall
    By JasonWallis in forum Structure - General Questions
    Last Post: January 24th, 2013, 09:51 AM
  4. Curtain Wall with base offset of 2' - help please.
    By digitalputty in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2012, 08:42 PM
  5. Curved wall opening / faced based family opening to curved wall
    By tjgreatrex in forum Architecture and General Revit Questions
    Last Post: November 11th, 2011, 01:48 PM
