Results 1 to 5 of 5
Thread: Pipe Insulation
    July 26, 2018
    4
    03:52 AM
    Pipe Insulation
    Hello
    As you can see i'm trying to insulate the piping system and everything is fine, but when i want to insulate the header (collector), the end cap part just doesn't get insulated, anyone has any idea on how to solve this?
    tnx
    Member philsogood's Avatar
    June 30, 2016
    Lyon - France
    132
    12:22 AM
    hi
    no solution : you have to create a cap family where you add insulation
    (your cap end are really amazing)
    Phil
    July 26, 2018
    4
    03:52 AM
    Quote Originally Posted by philsogood View Post
    hi
    Phil
    Thank you Phill for your reply ), after searching the net, i found that there are many others out there facing the same problem, and the fact is Revit insulation method can't follow the actual shape of the element, in fact Revit insulation is just like a simple sweep which can adapt just to pipes and nothing else, tnx for your proposition, i will try that.
    and one more thing, if I edit my cap family and add insulation to it, would it be displayed in the insulation schedule too?
    December 24, 2018
    1
    11:22 PM
    What is the current status?
    February 22, 2013
    316
    07:22 PM
    Quote Originally Posted by Dave_Malek View Post
    I just created some pipe and applied insulation to it. The cap is insulated and that insulation shows up in a pipe insulation schedule, but it's a standard "flat" pipe cap. I wonder if the dome shape of your pipe cap family is fouling things in some way.
  1. Pipe insulation issues
    By Karliaau in forum MEP - General
    Last Post: June 28th, 2017, 12:47 PM
  2. Bottom Of Pipe Insulation
    By mpwolfe in forum MEP - General
    Last Post: June 24th, 2016, 01:36 PM
  3. Pipe/duct Insulation
    By nick_h in forum MEP - General
    Last Post: June 22nd, 2013, 01:26 PM
  4. Pipe Insulation
    By Devon in forum MEP - General
    Last Post: October 29th, 2012, 01:39 AM
  5. Building Coder: Pipe Insulation and Insulation Material
    Last Post: May 24th, 2012, 09:15 AM
