Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By tzframpton
  • 1 Post By josephpeel
Thread: Plumbing fixtures inherit color
    January 3, 2017
    26
    09:52 AM
    Hello everyone, there is a problem with plumbing fixtures that inherit the color of pipes when connect to them.for example when im drawing the sanitary system and piping Bidet , it turns green and in Rendering part still remains green. Can u help me?
    Sent from my SM-N920C using Tapatalk
    January 17, 2011
    1,969
    03:52 AM
    This is not a "problem", but a known function of Revit. Plumbing Fixtures inherit the system Graphic Override color that it's connected to. You have a couple of options:
    1. You can remove Graphic Overrides altogether (I did this many years ago) and color your systems another way: for instance using Filters and controlling the color of pipes and fittings only.
    2. If you prefer Graphic Overrides, you can create a Filter for Plumbing Fixtures and apply the color Black to the filter's line color. Filters do override Graphic Overrides.
    -TZ
    cganiere likes this.
    January 3, 2017
    26
    09:52 AM
    Quote Originally Posted by tzframpton View Post
    -TZ
    Thank you , helped me a lot☺☺
    May 3, 2012
    1,392
    10:52 AM
    System overides only work when there is one system type connected. So you could add another.
    I assume your toilet will need a water connector as well? Add one in the family. Then select the toilet, click create piping system and select water (Or connect a water pipe if you are modelling that too). The colour overide will dissapear because the toilet has more than one system.
    tzframpton likes this.
    January 17, 2011
    1,969
    03:52 AM
    Quote Originally Posted by josephpeel View Post
    Good note, Joseph. One thing I will note though, is while this is a solution for multi-connection fixtures/equipment/etc, this will obviously not work with single-connection fixtures/equipment/etc.
    -TZ
    January 3, 2017
    26
    09:52 AM
    Yes exactly. you are right, But in some fixtures such as flash tank we need only a water connector. I used this idea for toilet. Thank you alot
    January 3, 2017
    26
    09:52 AM
    -TZ
    I truely appreciate your time and response
  1. Visibility of Plumbing Fixtures
    By shannononeal in forum MEP - General
    Last Post: March 2nd, 2016, 10:51 PM
  2. Electrical Discipline and Plumbing Fixtures
    Last Post: July 16th, 2013, 01:34 AM
  3. plumbing fixtures are boxes?
    By archgirl86 in forum Architecture and General Revit Questions
    Last Post: July 3rd, 2013, 12:55 AM
  4. Parametric Plumbing Fixtures
    By jonlenk in forum MEP - Family Creation
    Last Post: October 22nd, 2012, 08:09 AM
  5. Tagging Plumbing Fixtures
    Last Post: January 27th, 2011, 05:23 PM
