Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Twiceroadsfool
Thread: New MEP Connecting to Not Visible Workset
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    245
    09:25 AM
    Using 2018
    I'm trying to do my first project using a workset to do demolition instead of the awful built in phasing. One issue I'm having is that elements I draw in my new work view are trying to connect to "demolished" elements. Is there any way to stop this behavior?
    10,280
    08:25 AM
    Dont use worksets for Phasing. Its going to continue to cause this (and other) problems.
    April 30, 2015
    Michigan
    245
    09:25 AM
    I just hate the way phasing works so much.
    10,280
    08:25 AM
    Well, if you do it with Worksets: The connections will all be jacked up, youll have pieces missing where joints are that youve turned off with worksets (which will mean exporting to navisworks will be a mess), your consultants will be irate (they are now stuck managing your model with workset visibility, which they dont want to do), demolished objects dont show up correctly, systems are useless...
    Basically, itll be a disaster.
    Just my two cents though.
    tzframpton likes this.
    Member kubsix's Avatar
    March 31, 2011
    Quad Cities, Illinois
    292
    08:25 AM
    Uncheck Automatically Connect when routing the element.
    Loved using Revit phasing when it worked for ducts and pipes. Demolition of systems has been jacked since v 2013 which removed the last of the identification parameters (systems type, name, abbrev, etc.) and thus filtering capabilities between the trades, let alone disconnecting everything. PITA. As much as I despise using worksets for visibility it is a valid solution for the current state of demo debacle.
  1. roof not visible in enlarged plan view but visible in all other views 2017
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: December 13th, 2017, 09:00 PM
  2. Replies: 1
    Last Post: November 25th, 2015, 12:46 PM
  3. Want 'non-visible' elements to be non-visible, not grayed out
    By billiam in forum Architecture - Family Creation
    Last Post: April 2nd, 2015, 09:53 PM
  4. Connecting 2 concrete beams
    By Robin Deurloo in forum Architecture and General Revit Questions
    Last Post: October 12th, 2011, 07:49 PM
  5. Context Masses Visible Good, Concept Masses Visible Bad
    Last Post: June 14th, 2011, 05:11 AM
