Results 1 to 2 of 2
Thread: Groups problem: Copy/Paste (Aligned to Selected Levels)
    July 13, 2018
    4
    10:47 PM
    Post Groups problem: Copy/Paste (Aligned to Selected Levels)
    Hello! When i create groups (pipes+air conditioner unit), i need to copy and paste it to other levels because i have typical floor. Then some error show: "Elements need to be disconnected". I click to "Disconnect" and show "Group instances of the same type do not contain identical members. Press "Fix Groups..." to select from options to make the groups consistent. Corresponding group members in different group instances diverge in the following respects: - different base heights relative to the group origin".
    I need a solution! Please help me!
    Thank you!
    Junior Member WelcomeToAccord's Avatar
    April 5, 2018
    Florida
    21
    06:47 PM
    Lightbulb
    Have you checked the height of each part? Most pipes and HVAC components tend to stay at the same elevation, but you might have a component that's not connected or doesn't automatically connect to the other components.
    For now, you can move specific parts of the group individually. I'll experiment and see what happens when I move a group of pipes and fittings up to another floor.
  1. Copying and Pasting Using Aligned To Selected Levels
    By Simon 2 in forum Architecture and General Revit Questions
    Last Post: May 18th, 2016, 01:06 PM
  2. Replies: 0
    Last Post: June 6th, 2014, 04:45 AM
  3. Revit OpEd: Columns and Paste Aligned
    Last Post: December 20th, 2013, 05:15 PM
  4. Paste component to selected levels, multiple instances, still warning.
    By nathanjh13 in forum Architecture and General Revit Questions
    Last Post: December 19th, 2013, 08:16 PM
  5. Copy & Pasting using Paste Aligned to Same Place - not coming in at same place
    By cheinaranta in forum Architecture and General Revit Questions
    Last Post: June 14th, 2013, 08:32 PM
