Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By tzframpton
Thread: converting from Autocad 3D to revit
    June 28, 2018
    1
    11:19 AM
    Question converting from Autocad 3D to revit
    Hello,
    I have a project that is saved on Autocad 3D , and i wanna convert it into revit !
    my question is , do i need to rebuild all the elements (walls, floors, piping , cable path ...) ?
    is there are any extensions or another softwares that allows me to find the elements builded while converting !
    Best regards !
    January 17, 2011
    1,969
    04:19 AM
    To do it right, you'll have to remodel it. There is one known workaround where you can import the 3D model into an In-Place Family as a Generic Model which gives you a certain level of control but it's far from an ideal solution.
    -TZ
    WelcomeToAccord likes this.
    Junior Member WelcomeToAccord's Avatar
    April 5, 2018
    Florida
    21
    05:19 AM
    Smile Work Clean, Less Mean
    In order to avoid issues and use clean "families", it would be best if you imported a 2D version of the MEP objects and used Revit families to re-create your project. It'll take less time than it seems, and your end-result should work well and be 100% Revit-friendly. AutoCAD imports tend to be inconsistent based on whether or not you're importing 2D lines or 3D complex MEP objects.
  1. Converting AutoCAD Details to Revit
    By RobDraw in forum MEP - General
    Last Post: January 29th, 2016, 10:20 PM
  2. converting drafting views to previous version revit
    By haydenrrr in forum Architecture and General Revit Questions
    Last Post: December 8th, 2015, 12:52 PM
  3. Converting from Revit to AutoCAD dimension trouble.
    By noprs in forum Architecture and General Revit Questions
    Last Post: November 20th, 2015, 10:29 PM
  4. converting ACAD details for Revit use
    By cogan in forum Architecture and General Revit Questions
    Last Post: April 21st, 2015, 04:27 PM
  5. Replies: 0
    Last Post: November 18th, 2011, 04:15 AM
