Results 1 to 3 of 3
Like Tree3Likes
  • 2 Post By Necro99
  • 1 Post By Steve_Stafford
Thread: Double line and single line pipes based on size?
    Junior Member Theophilous's Avatar
    February 1, 2012
    Vancouver Wa.
    36
    06:43 AM
    I just received a request for Revit to show double line pipes based on size of the pipe.
    First I said, No that's not possible, but then I was thinking of a workaround to accomplish this, maybe filters, but that's a no go...
    Has anyone tried to show both single line & double line pipes in the same view based on pipe size.
    4" pipe size and larger to be double line.
    Thanks in advanced!
    February 22, 2013
    327
    09:43 AM
    Nope, not possible. I've seen some people suggest overlapping two viewports with different filter settings but f that noise. I usually do my best to accommodate requests like this at my office but in this instance my answer has been a succinct "Nope."
    Twiceroadsfool and tzframpton like this.
    Mr. Revit OpEd
    2,866
    06:43 AM
    Pipe placeholders are single line only, you could draw with those for the small diameter piping.
    tzframpton likes this.
  1. help to display pipe with with only single line
    By trang_chau in forum MEP - Family Creation
    Last Post: April 18th, 2016, 02:13 AM
  2. Line Based Family nested inside another line based family and arrayed
    By MadMatt in forum Architecture - Family Creation
    Last Post: January 6th, 2013, 05:29 PM
  3. Array a line based family inside another line based family
    Last Post: December 11th, 2012, 01:08 PM
  4. single parameter re-size sweep-blend based on locked angle constraints
    By aheintze in forum Architecture - Family Creation
    Last Post: August 1st, 2012, 03:07 PM
  5. representation of beams is just single line !!!!!?
    Last Post: January 1st, 2012, 09:10 PM
Tags for this Thread
