Results 1 to 2 of 2
Thread: Can a pipe fitting be converted into a pipe accessory?
    June 10, 2015
    91
    07:05 PM
    Looking to convert pipe elbows into radiator valves without having to manually delete the elbow then add the valve. Can this be achieved?
    Thanks
    Andy
    May 3, 2012
    1,396
    08:05 PM
    Hmm.. possibly. You could first make a separate elbow family for the radiator valves and select it everywhere you want to convert (So you dont convert all your elbows). Then with one of 'valve' elbows selected do Edit Family, change the category to Pipe Accessory, then reload/overwrite. At that point you can select all the 'valve' elbows and switch them for your valve family..
    However, its unlikely this will work without generating a load of errors. For, one thing the positioning of the connectors in your radiator valve family and the parameters that control the size will need to be exactly the same as in the elbow.
    You could also directly switch pipe fittings to pipe accessories using Dynamo, but the likelihood of errors would be the same.
  1. Pipe-in-pipe, containment pipe, double-wall pipe ?
    By gerryblake in forum MEP - General
    Last Post: June 14th, 2017, 04:14 PM
  2. Pipe Fitting Connections to each other/NO Pipe
    By se13gits in forum MEP - General
    Last Post: July 8th, 2016, 01:56 PM
  3. System Seperators - Mechanical Equipment -vs- Pipe Accessory
    By evan.dodds in forum MEP - Family Creation
    Last Post: January 22nd, 2016, 02:20 AM
  4. Constraining Array Length/Depth on Pipe Accessory
    By wgfletch in forum MEP - Family Creation
    Last Post: June 4th, 2015, 11:13 PM
  5. Pipe fitting. Who can help?
    By domsib in forum MEP - Family Creation
    Last Post: January 30th, 2015, 03:33 PM
