Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By GlynnisPatterson
Thread: Interference Check by element
    June 10, 2015
    91
    01:51 AM
    Anyway you can run an interference check for clashes by element(s) without having to do the entire model?
    Eg. Check pipe against ducts and cable tray on Level 1 Zone 3.
    Tnaks
    Andy
    February 29, 2012
    63
    07:51 PM
    You can select the pipes and ducts then use Interference Check and use the 'selected elements' option.
    elton williams likes this.
    October 17, 2018
    1
    12:51 AM
    Allo,
    Does interference check consider floating or totally unconnected pipes or ducts as a clash? or does it ignore them and automatically consider them work in progress?
  1. Interference Check
    By andyrh1982 in forum Architecture and General Revit Questions
    Last Post: November 21st, 2016, 01:42 PM
  2. Interference Check Help
    By waikikigirl in forum MEP - General
    Last Post: October 16th, 2015, 06:22 AM
  3. Interference check
    By fifthtexas in forum MEP - General
    Last Post: August 28th, 2015, 03:38 PM
  4. Replies: 0
    Last Post: January 7th, 2014, 11:45 PM
  5. Revit OpEd: Detail Level and Interference Check
    Last Post: November 13th, 2013, 08:15 PM
