Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Like Tree6Likes
Thread: PDF's into Revit?
    February 22, 2018
    Vancouver, Canada
    26
    02:30 AM
    PDF's into Revit?
    I'm not sure if this is the correct place to post this, but has anyone had any success getting PDFs into Revit? Currently I can insert the PDF into Autocad and save it and then link it into Revit, but is this the only way?
    March 21, 2013
    Phoenix, AZ
    275
    03:30 AM
    Print (or convert) the PDF to an image, and link the image into Revit.
    February 22, 2018
    Vancouver, Canada
    26
    02:30 AM
    You mean a jpeg file? do you think that is the best way to model over top of a PDF in the revit environment
    Member HansLammerts's Avatar
    April 22, 2011
    440
    11:30 AM
    Ask the *native files* from the creator! Don't accept pdf ( baseline attitude)..
    July 10, 2015
    Boise, Idaho
    591
    03:30 AM
    All the time. I have the PDF open on one screen and model everything properly on the other screen.
    December 8, 2010
    Long Beach, CA
    187
    02:30 AM
    Quote Originally Posted by NAILZ7 View Post
    Yes, a jpg. Have you tried bringing a PDF into Revit via AutoCAD? It isn't possible. There is no way to bring a PDF in. An image is your only option. But you said you were successful? I'm interested in seeing how you pulled this off. Linking PDFs into Revit is on the Autodesk Roadmap, so maybe you'll see that capability in version 2020 or 2021.
    But as far as modeling, I'd do like the other posters and use the PDF side by side as a visual reference and not model over top of it.
    April 22, 2011
    440
    11:30 AM
    print it to paper, saves energy.
    cganiere likes this.
    Coeur d Alene, ID
    4,597
    02:30 AM
    Open in Map and convert to a native DWG (as long as the PDF is not an image)...
    PDF to Revit is now on the Revit Roadmap.
    February 22, 2018
    Vancouver, Canada
    26
    02:30 AM
    Since AutoCAD 2017 was released there is a function where you can insert the PDF into Autocad and it converts it into CAD elements, if it was drawn with a similar program. Then you just save the .dwg and link it into revit as you would with any normal .dwg.
    July 10, 2015
    Boise, Idaho
    591
    03:30 AM
    I don't even trust my own AutoCAD drafting to be precise enough to be used in Revit let alone something converted several times. That's just asking for that .000000001" error making it impossible to dimension anything.
