Results 1 to 5 of 5
Thread: Revit Design to Fabrication tool
    February 22, 2018
    Vancouver, Canada
    30
    05:34 PM
    Has anyone used the "Design to Fabrication" tool inside Revit to convert generic Revit duct to Fabrication parts? I am using Revit 2018 and it doesn't seem to be working. Any suggestions would be appreciated. Thanks
    Member TFuller's Avatar
    March 7, 2014
    Evansville, IN
    374
    07:34 PM
    How are your button mappings?
    February 22, 2018
    Vancouver, Canada
    30
    05:34 PM
    yep, i'm working on it. Its a bit tedious at the moment because its such a large project and it was the engineering team that ran the generic duct in revit, so I have to use their families
    March 7, 2014
    Evansville, IN
    374
    07:34 PM
    I discovered an issue with it not filling rediltee the way my button mappings were set up, so that is a known issue. I had it set to use a lateral tap (hole cut in the duct and the tap screwed to the duct body) but Revit insisted on using an actual full-bodied tap fitting (duct barrel body and tap all-in-one).
    My high efficiency taps were never "connected" to the main either. Never resolved that issue. May be in the ITM somewhere...
    February 22, 2018
    Vancouver, Canada
    30
    05:34 PM
    Yes TFuller, I noticed that it had some major issues with Duct with prefabbed holes. My solution was to create the objects in CADmep and then import the .MAJ file. Once I had one in the model I was able to edit and use in multiple locations.
  1. Replies: 0
    Last Post: August 1st, 2016, 11:45 PM
  2. Replies: 0
    Last Post: May 30th, 2016, 11:15 AM
  3. Replies: 0
    Last Post: May 21st, 2015, 11:15 PM
  4. What Revit Wants: Where fabrication and design meet
    By luke.johnson in forum Blog Feeds
    Last Post: November 8th, 2011, 11:45 PM
  5. Replies: 0
    Last Post: October 26th, 2011, 11:16 AM
