Results 1 to 5 of 5
Thread: Valve schedule per room ?
    June 5, 2015
    88
    02:28 AM
    Is there a way to schedule valves per room ? Having a schedule showing all the valves
    within in a room
    January 9, 2018
    5
    10:28 PM
    Short answer is nope - the Pipe Accessory category is not aware of either Rooms or Spaces.
    You'd need to either do it manually, adding a parameter and filling it out. Or get someone to write a utility to do it.
    May 3, 2012
    1,392
    07:28 AM
    Pretty easy with Dynamo, kept me amused while drinking my coffee..
    Attached Thumbnails Attached Thumbnails Valve schedule per room ?-space2acc.png
    Attached Files Attached Files
    January 9, 2018
    5
    10:28 PM
    Very nice!
    May 3, 2012
    1,392
    07:28 AM
    Just to add to this..
    The 100% revit, non-programming solution to scheduling accessories or other things that dont know what room they are in is to add a shared, nested family to all your accessory families. For example a tiny block that is Mechanical equipment and has one of its parameters linked to the Type/Model/Description of its host family.
    Then you can schedule them, see what accessory they belong to, and see what room they are in.
    This is also a way to get all the different categories in one schedule, or if you make the nested family movable, you can also use it to correctly link duct accesories outside a space (eg duct heater in corridor that heats the room) by moving the scheduled block into the room.
  1. Replies: 1
    Last Post: July 18th, 2018, 03:24 PM
  2. Door Schedule - To Room From Room
    Last Post: June 7th, 2017, 12:55 PM
  3. Room aware family - no "room: area" field available in schedule?
    By Paliskoo in forum Architecture and General Revit Questions
    Last Post: January 12th, 2016, 06:32 PM
  4. Room search from Room Schedule
    By aykhan9 in forum Architecture and General Revit Questions
    Last Post: November 6th, 2014, 04:57 PM
Tags for this Thread
