Results 1 to 5 of 5
Thread: Placing valves
    September 28, 2017
    24
    11:21 PM
    Placing valves
    When placing valves into a project i can not get it to keep a flange on the valve is there some way after placing the flange onto the valve and pulling the pipe to it for it to keep that flange.
    May 3, 2012
    1,346
    06:21 AM
    Yep. Make a Valve family with built in flanges that you can turn on and off. The Flange system in revit sucks.
    September 28, 2017
    24
    11:21 PM
    So when doing material take off then how can you get it to report on the flanges on the valves.
    May 3, 2012
    1,346
    06:21 AM
    1. Parameter in the valve family that gives the number of flanges that are on, so you can total up the quantity.
    or
    2. Shared families for Flanges in the valve family, a bit more complicated to make but has the advantage of being able to schedule all the flanges separately with other info such as type, size etc. Link a parameter to the description of the host valve so you can also see what valve it is attached to in the schedule.
    September 28, 2017
    24
    11:21 PM
    Thanks for your help. I am new to Revit and its big learning curve compared to the Auto CAD
  1. Assign Room Names to Valves
    By mdomer in forum Architecture and General Revit Questions
    Last Post: February 16th, 2016, 03:06 PM
  2. BIM Modelling - plumbing valves and fittings
    By Rdrybala in forum Dynamo BIM
    Last Post: February 5th, 2016, 12:04 PM
  3. Flip Controls on Valves?
    By evan.dodds in forum MEP - Family Creation
    Last Post: November 24th, 2015, 10:29 PM
  4. Auto-sizing Valves
    Last Post: September 7th, 2015, 10:41 AM
  5. Isolating Valves
    By domsib in forum MEP - Family Creation
    Last Post: April 11th, 2013, 03:10 PM
