Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 54
Like Tree68Likes
Thread: Black vs White Background
    Member koolair's Avatar
    July 31, 2014
    190
    05:37 AM
    Recently I ran into a Revit modeler who prefers a white background. I was like 🤣.
    But then he explained that color pdfs look exactly the same in the model vs paper so observers aren't confused when looking over your shoulder. He actually rarely does black and white since everyone uses Bluebeam.
    I prefer black for my eyesight and black's similarity with CAD and its pre existing color settings but this fellow raised a good point. But I were to change to white, I'd have to change some of my colors because they're very light.
    Is it worth it? Curious...
    9,178
    04:37 AM
    230/230/230.
    And every time i have to go in my Structural Engineers model (who uses a black background and has colors on everything) i want to claw my eyes out.
    tzframpton, dzatto, Drew and 2 others like this.
    June 21, 2012
    Tours, France
    750
    11:37 AM
    Quote Originally Posted by koolair View Post
    Recently I ran into a Revit modeler who prefers a white background. I was like 藍.
    I'd been using black background 33/40/48 recently, mostly for my eyes and I found it very confortable since I just have a new screen that is quite luminous , I think that using a black background is a good idea, but for the PDF's I'm agree with you: colors are most similar in withe background than in the black one
    Regards
    Senior Member
    December 16, 2010
    775
    07:37 PM
    Its entirely preferential, but I made the change from black screen to white screen many years ago when I started using revit.
    I actually find the white screen a bit easier in some ways. Sure I don't have the color coding but this is the trap of trying to make revit look like cad. Its not, stop trying to make it the same interface. There is no need to put that many colors on your screen in revit because the thickness of the line is not handled by color coding as in Cad.
    If you want to see the thick lines then its there (personally I prefer to work with thin lines active so I can see errors in alignment) but if you need the visual reassurance all the time its there. Another reason I don't need color coded layers like in CAD is that I can easily interrogate an element if I'm unsure what it is. In fact in most cases I don't need to because I have a 3d model which verifies instantly for me "by eye" if the element I am seeing on screen is a wall, or a slab, or Something else. I mean this is the purpose of layers in CAD is to identify what it is thats drawn, this need is removed in the revit environment.
    The only colors I want to see on screen are the colors that are going to print on the page, the rest prints as black lines on a white page so I have a cloned image of what will print in front of me its much easier to manage. Also I have 100% confidence in my templates and material settings that line thicknesses are right, I don't need the crutch of color coded layers to reassure me that a yellow line is indeed a wall and that the yellow line will print at 0.35mm thickness.
    When you really break it down, the color coding is simply a visual verification that you have used the correct layer to indicate an element and in reality this breaks down to layer control (ie being able to mask layers by "category" - assuming your drafters have actually respected your layer conventions). This "need" is completely removed in revit. A wall is a wall, and will export as a wall and its up to you to control the thickness of the lines in your view templates but this is a one shot thing and actually your drafters using your Template will have no choice but to use your "layer convention" because it is forced to some degree by revit templates.
    The major problem with using color lines in revit is that you are forced to print in black and white. And then what happens when you want to actually put Something with color on your black and white plans? You can't...because you cant print one element in color (like a tag, or a note, or a logo) and print the rest in black and white. Its either color printing, or everything on the page black and white...
    cganiere, DaveP and koolair like this.
    December 21, 2010
    C.LONDON
    4,231
    10:37 AM
    I've recently started use alternative colour backgrounds for (some of) my (working) 3D views; a dark slate-grey so that materials "pop", and a deep burgundy for "QA" views.
    josephpeel likes this.
    Senior Member
    December 16, 2010
    775
    07:37 PM
    Sure I use color for working views to highlight coordination issues for example (3D), but these are not "production" views ie they never make it to a sheet, or an export file.
    May 3, 2012
    1,302
    11:37 AM
    The best thing about a white background is it stops people using Yellow on drawings.
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,357
    03:37 AM
    I use off white too, for eye strain. Especially with the use of 3d views, the white lines for edges is really distracting when I see a coworkers view.
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    248
    04:37 AM
    230/230/230.
    This is the only way structural engineers should be using colors... IMO.
    Attached Thumbnails Attached Thumbnails Black vs White Background-capture.jpg
    Senior Member
    December 16, 2010
    775
    07:37 PM
    Or this - color is useful, but you arent going to use it the same way you did in autocad
    Attached Thumbnails Attached Thumbnails Black vs White Background-capture.png
  1. White text showing on a black filled region
    By LindseyMcLaughlin in forum Architecture and General Revit Questions
    Last Post: November 9th, 2016, 04:53 PM
  2. Background turned black
    By FrenchQuarters in forum Architecture and General Revit Questions
    Last Post: November 6th, 2015, 01:39 AM
  3. how can i remove the dimensions white background ?
    By Ahmed A.Kader in forum Architecture and General Revit Questions
    Last Post: November 17th, 2014, 11:50 PM
  4. Printing - Black & White
    By domsib in forum Architecture and General Revit Questions
    Last Post: September 12th, 2014, 02:50 PM
  5. Print in Color or Black and White
    By rboaz in forum Architecture and General Revit Questions
    Last Post: November 22nd, 2011, 09:49 PM
