Results 1 to 3 of 3
Thread: change system type
    Member philsogood's Avatar
    June 30, 2016
    Lyon - France
    137
    11:18 AM
    change system type
    hello
    i should definetly do not working with the good tips
    I used to work on ACAD and i often copied items from one pipe/duct to another.... i'm doing the same on revit (because i need to copy the valve AND the flanges) but when i do this the items stay on the system type from where i take them.... and it's very hard to change it to the right system...
    most of the time i need to delete flanges, then insert valve (for example) on my pipe then insert the flanges.... so boring...
    how do you do so easy things? is there something i missed?
    Phil
    January 17, 2011
    2,008
    06:18 AM
    This is pretty easy actually: just hover over the pipe and keep cycling the Tab key until you see a boxed dotted line that surrounds the entire network of pipe/fittings/accessories. Then, left click once. This "selects" the system. Hit the delete key. This will remove the system and it will convert to an Undefined system. When you connect this piping network to a new system, it'll absorb the system it's conning into. Or, since it's Undefined, when you route new pipe you now have the option to select what system you want.
    But if the System Classification is the same, you can select the System and change it to another. Storm Drain and Storm Overflow for instance can be interchanged easily without deleting the Piping System since they're both Sanitary System Classifications, etc.
    Hope this helps.
    -TZ
    June 30, 2016
    Lyon - France
    137
    11:18 AM
    many many thanks TZ!!
  1. Assign Default System Type to Pipe Type
    By mdouglass in forum MEP - General
    Last Post: June 9th, 2016, 06:31 PM
  2. Replies: 0
    Last Post: May 18th, 2015, 03:45 AM
  3. How to change system type of pipework
    By fifthtexas in forum MEP - General
    Last Post: November 13th, 2014, 03:58 PM
  4. how could we change rebar bar system ???
    By Eng.N.3D.All in forum Structure - General Questions
    Last Post: August 29th, 2014, 06:53 PM
  5. change system classification after modeling
    By spotless in forum MEP - General
    Last Post: December 9th, 2013, 05:16 PM
Tags for this Thread
