Results 1 to 2 of 2
Like Tree2Likes
  • 2 Post By LukeEvans
Thread: Fabrication Parts - Connector Change
    September 15, 2016
    10
    11:09 AM
    Does anyone know if there is an easy way to change duct connectors in fabrication parts?
    Thanks,
    September 16, 2015
    Darwin, Australia
    171
    02:39 AM
    The best way to have the right connector from the start is to edit the service specifications in a fabrication product (CAMduct, ESTmep, CADmep). Other than that there is no quick way to change a connector inside of Revit. You have to open the 'Edit Part' window every time.
    Hmmmm... You've got me thinking that it's possible to change the connector with an instance parameter in Properties window with the help of Dynamo. Let's see how far I get...
    tzframpton and MChilds like this.
  1. Replies: 0
    Last Post: May 9th, 2017, 07:01 PM
  2. Mapping Revit MEP Families to MEP Fabrication Parts
    By kanderson in forum MEP - General
    Last Post: December 8th, 2016, 01:58 PM
  3. Fabrication Parts failed to install in 2017 ?
    By ryntau in forum MEP - General
    Last Post: October 8th, 2016, 02:06 AM
  4. Revit 2016 Fabrication parts
    By lukemcgary in forum MEP - General
    Last Post: July 11th, 2016, 06:16 PM
  5. Revit MEP 2016 Fabrication Parts
    By Chris.kershaw in forum MEP - General
    Last Post: May 4th, 2015, 06:22 PM
