Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Like Tree3Likes
Thread: Multistory aparment block
    Senior Member
    November 27, 2012
    547
    03:59 AM
    What is the best way to do the MEP in a multistory apartment block, where floors there is only 2 different floor levels throughout?
    so you dont have to keep doing loads of repetition and multiple changes if one floor changes.
    Senior Member
    November 27, 2012
    547
    03:59 AM
    Quote Originally Posted by nick_h View Post
    any help on this?
    April 20, 2015
    110
    03:59 AM
    is there any BIM requirements saying you have to model every floor? if not Id just model the 2 floors & note on the title sheet that its floor 2, 4, 6 or what ever floor it is then for your kit id have a numbering system that has the floor in it something like RAD-10-01 where the 10 is the floor & 01 is the number.
    March 14, 2017
    9
    03:59 AM
    I'm in a similar place, with a similar problem. Your proposed solution is what I'm looking at doing. However, what happens if we have to account for equipment on the floors that haven't been modeled? Is there a means of following this process, yet scheduling all equipment that is on the identical floors that aren't modeled?
    One thing I have looked at is grouping the equipment modeled on one floor and copying this group onto the floors that share the same layout. Would you say that this is a feasible solution?
    Senior Member
    November 27, 2012
    547
    03:59 AM
    Quote Originally Posted by Chris.kershaw View Post
    that is brilliant Idea, and will more that use that.
    was thinking of using model groups, and copying the duplicate floors, but not sure how well that works?
    April 20, 2015
    110
    03:59 AM
    Yeah that would work for a total number of things, but you would not be able to give each an individual number
    April 20, 2015
    110
    03:59 AM
    Never tried multiple number of large groups so not sure if it would slow down the model at all
    Senior Member
    November 27, 2012
    547
    03:59 AM
    I dont really like the idea of it, but wasnt sure what the best method is, im sure I read somewhere about exporting out the floor and linking it back in on multiple floors
    if anyone else has any input on this please let me know.
    8,582
    09:59 PM
    Linking it will be 100x the diaster that Groups will be.
    Groups only *slow down* the project because there is suddenly that much more stuff in the model. Thats not a bad thing. Linking in floor plates? Will drag that model to a halt any time you go to create a new view, to the point that it wont be a good user experience.
    And Linking wont solve your numbering/tagging issues. Youll have to call the equipment X01, and then schedule the linked file name for X.
    Go with Groups.
    Junior Member kiodour's Avatar
    February 17, 2013
    Jamaica
    5
    09:59 PM
    I do something similar for Slab Edge & Coordination models... Provided that slab thickness and elevation apart are typical.
    However, if you use this method be sure to make a note of the elevation of each floor.
  1. How do you handle Multistory typical levels in Revit?
    By abcd in forum Structure - General Questions
    Last Post: April 8th, 2014, 07:05 PM
  2. Multistory Railing Visibility
    By RaiderArch in forum Architecture and General Revit Questions
    Last Post: February 20th, 2014, 04:28 PM
  3. (Multistory) Stairs Beyond Cut Line
    Last Post: September 6th, 2012, 10:53 AM
  4. Replace tilet block with title block
    Last Post: May 4th, 2012, 09:48 PM
  5. Multistory piping sytem, system browser
    By Fekoloid in forum MEP - General
    Last Post: November 14th, 2011, 01:13 PM
