Donate Now Goal amount for this year: 3000 USD, Received: 2290 USD (76%)
Results 1 to 4 of 4
Thread: Quality Record
    November 18, 2013
    Germany
    64
    02:11 AM
    Quality Record
    Hello Reviter,
    MEP is a quite complex field. It’s hard find employers are fit in Revit and MEP.
    So, I am fit in Revit, but I am an architect. I must develop a white paper, to make a Quality record paper. Does anybody have experiences in this field.
    What are the basic-zones to test a MEP- Modell in Revit?
    What are the key-areas?
    Which advices can I give planers?
    I have classic “prof-tools” like BIM-link, Family size reporter, but else is on the market?
    Maybe a dynamo script? Or other plug-ins they are important to test a data model?
    I am glad about to receive any advice !
    BR
    Andreas
    December 21, 2010
    C.LONDON
    4,175
    02:11 AM
    Quote Originally Posted by andreasdraxl View Post
    My first piece of advice? Breathe.
    You really need to break your OP down a bit - you are lightly-touching on (too many) tangential topics.
    Let's start with:
    Q. What do you mean by "a Quality record paper" ?
    October 29, 2012
    Graz, Austria
    8
    01:11 AM
    ... it is a Check-list to walk systematicly thrue the building(f.e. check dataamaount, used families, opening time, worksets,...)
    Are there check-lists for MEP stuff. Or maybe plug-ins to test a datamodell in different ways. I am not talking about clashes. Its more regarding the dataquality!
    and how can i meantain that.
    May 3, 2012
    1,275
    03:11 AM
    You could check for things like;
    -Do all pipes and ducts have a System associated (Not Undefined)
    -Are systems reporting information like flow rates (So they are well connected and can be used for calculations)
    -Is there a consistent numbering/coding system for what components are (Eg Uniformat or Uniclass codes in Assembly code parameter)
    But yes, MEP is complex and hard to define rules for.
  1. Record Drawing Revision
    By andyrh1982 in forum Architecture and General Revit Questions
    Last Post: August 10th, 2016, 03:44 PM
  2. BIM Manager of Record
    Last Post: April 11th, 2016, 01:07 PM
  3. Replies: 0
    Last Post: January 26th, 2016, 10:15 AM
  4. Replies: 0
    Last Post: November 21st, 2014, 12:15 PM
  5. Replies: 0
    Last Post: May 23rd, 2012, 11:45 PM
