Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Like Tree3Likes
Thread: Cobie data
    Senior Member
    November 27, 2012
    554
    12:56 PM
    Cobie data
    When filling in the cobie data for Air terminals etc.. do you input the location per terminal or is there anyway of cobie picking the data up directly from the spaces
    April 20, 2015
    110
    12:56 PM
    Make sure your grilles room calculation point is turned on in the family & is below the grille & it should populate that for you
    Senior Member
    November 27, 2012
    554
    12:56 PM
    so when i export the cobie data on and open it in excel and the room locations should be populated?
    April 20, 2015
    110
    12:56 PM
    Yes but you have to have Spaces with the room names within your model too
    Senior Member
    November 27, 2012
    554
    12:56 PM
    do you have any examples of what it should look like with cobie data filled in? in the past the architect has taken care of all this.
    April 20, 2015
    110
    12:56 PM
    Not at hand but will post some ASAP
    Senior Member
    November 27, 2012
    554
    12:56 PM
    cheers for that.
    I thought I had would have to manually input all the location of equipment item by item
    Senior Member
    November 27, 2012
    554
    12:56 PM
    Quote Originally Posted by Chris.kershaw View Post
    did you manage to find any cobie mep stuff
    June 29, 2015
    94
    12:56 PM
    On my template, I have Space Categories (Uniclass 2015) and Ocupancy Zones parameters associated with my rooms. Whenever I am filling data from the room, I am also populating this data to help the MEP guys later.
    josephpeel and uaifestival like this.
    Senior Member
    November 27, 2012
    554
    12:56 PM
    Quote Originally Posted by asintoras View Post
    Have you got an example please
    for uniclass2015 do you just add a parameter to your familes and fill in the add the relevant uniclass category to the family?
  1. Cobie data input
    By fjtdogeno in forum Architecture and General Revit Questions
    Last Post: October 25th, 2016, 12:35 PM
  2. Data Base - Input Data
    By Lorraine in forum MEP - General
    Last Post: June 15th, 2016, 12:27 AM
  3. COBie Data Drops error - "Object reference not set to an instance of an object"
    By jana.honkova in forum Architecture and General Revit Questions
    Last Post: February 9th, 2015, 09:13 AM
  4. Cobie & MEP
    By nick_h in forum MEP - General
    Last Post: October 9th, 2014, 09:50 AM
  5. COBie data with Revit - Best Program?
    By tzframpton in forum Architecture and General Revit Questions
    Last Post: December 22nd, 2011, 10:44 PM
