Results 1 to 3 of 3
Thread: Ashrae
    August 27, 2015
    9
    11:23 PM
    Ashrae
    Hello world!
    I have an issue, currently working on developing an HVAC system we usually work on a Revit Server, as of now we are working in an individual project, when i set up the AHU and Air terminals and duct system it shows the system inspector and duct sizing.
    But when i try to size i have a coefficient loss, ive researched much and my deduction is im missing the ASHRAE .XML files, in the following i will link an image and im wondering if i can load the ASHRAE tables to the project and how so? It seems like not much information is found on the internet regarding this subject i appreciate the help.
    Vik
    May 3, 2012
    1,403
    04:23 PM
    If you can't get the ashrae table working (I don't know how this works...) you can also go into the families and set the pressure drop to "specific pressure loss". Then you can fill in a fixed pressure drop or link it to a formula. (Which is the only way to do it with non US standards).
    August 27, 2015
    9
    11:23 PM
    Ive tried doing the following before, i can change the elbows to specific loss or coefficient, but when i come to the tees i only have the ASHRAE table option or undefined. Im coming to the conclusion its a flaw in the 2016 version. So far i still have not found the proper solution
  1. ASHRAE 62.1 VRP Calculation
    By Necro99 in forum Dynamo BIM
    Last Post: July 29th, 2018, 10:40 PM
  2. Ashrae tables
    By Chris.kershaw in forum MEP - General
    Last Post: December 2nd, 2016, 07:03 PM
  3. Creating an ASHRAE Schedule
    By txelwood in forum MEP - General
    Last Post: April 25th, 2014, 08:47 PM
  4. Inside the System: ASHRAE Viewer Available in Labs
    By Inside the System in forum Blog Feeds
    Last Post: September 15th, 2011, 06:30 AM
  5. ASHRAE Viewer for Revit MEP 2011/2012
    By troygates in forum MEP - General
    Last Post: March 31st, 2011, 11:08 PM
