Results 1 to 3 of 3
Thread: Revit MEP-help!
    August 3, 2011
    15
    08:28 AM
    Revit MEP-help!
    hello all! my name is jared and I have been useing Revit MEP for a long time now. But recently I ran into a dilema. Please help if you have found a salution.. So i wanted to easily just copy and paste from one dwg to the other like Inventor, but that option isnt available when you right click the part that you want to copy. Is there another salution to this? Cause i really dont want to have to redraw the part.
    Member Jrobker's Avatar
    December 9, 2010
    Salt Lake
    178
    07:28 AM
    First off you need to have BOTH files open.
    Select the families you want to copy. hit ctrl+c or cut to clipboard in the modify tab (this is not a right click option).
    In the second file either hit ctrl+v or the modify tab there is a paste button with multiple options.
    Now keep in mind it isn't as always as easy as copy/paste. RMEP families share relationships with connected families. So getting a portion may not work. Sometimes it is easier to create a group and than copy/paste the group than ungroup.
    August 3, 2011
    15
    08:28 AM
    oh ok perfect! i will try that out. Thank you so much for your help. it is greatly appreciated.
  1. Invisible room tags (Revit MEP)
    By Justin8304 in forum MEP - General
    Last Post: October 25th, 2016, 11:06 PM
  2. Revit Kid: Revit MEP - Should we model the Existing?
    By The Revit Kid in forum Blog Feeds
    Last Post: July 18th, 2011, 01:30 PM
  3. Replies: 6
    Last Post: July 12th, 2011, 06:48 PM
  4. Transitioning from AutoCAD MEP to Revit MEP
    By tzframpton in forum MEP - General
    Last Post: May 16th, 2011, 12:41 PM
  5. Revit 2011 MEP and Architectural Processors
    By alaayehya in forum Hardware and Infrastructure
    Last Post: April 27th, 2011, 10:29 PM
