Results 1 to 2 of 2
Thread: Importing a Lighting Device annotation family into a switch family
    January 19, 2016
    India
    9
    06:17 PM
    Hi Guys,
    Can someone give me a suggestion how to import a Lighting Devices annotation family into a Lighting devices family.
    I have modeled a switch and need to import the annotation I created using the Lighting Device annotation template, but I cannot import the family into my Light Switch family, it can only import generic annotations. Can someone provide me a good solution.
    Thanks in advance.
    Autodesk - Sr. Revit QA
    November 17, 2015
    Boston, MA
    25
    01:17 PM
    Hi Abin,
    Use a generic annotation when creating annotations to nest into other families. The annotation families that have a category already called out are typically used when creating a tag to tag an element of that category. For example, a light fixture annotation family is typically used to create an annotation to tag a light fixture.
    You should be able to save the work you did in the Lighting Device annotation family by changing the category to generic annotation. Click on the Family Categories and Parameters button in the top left corner of the ribbon(it has a folder icon on it). Just change the category to generic annotation. Once you have done that you should be able to place it in your family.
    Thanks
  1. Replies: 3
    Last Post: April 7th, 2016, 07:24 AM
  2. Generic Annotation Family Not Visible with Deep Family Nesting.
    By MattKincaid in forum Architecture - Family Creation
    Last Post: March 30th, 2016, 08:54 PM
  3. Generic Annotation Family Not Visible with Deep Family Nesting.
    By MattKincaid in forum Architecture and General Revit Questions
    Last Post: October 8th, 2015, 11:12 PM
  4. Revit API - Switch off the host categories in a family document
    By jockholiday in forum Third party Add-Ins, API and R&D
    Last Post: August 14th, 2015, 12:34 PM
  5. Lighting Family w/annotation - what am I doing wrong?
    By Lkenshalo in forum MEP - Family Creation
    Last Post: May 20th, 2014, 11:32 AM
