Results 1 to 5 of 5
Thread: Pipe/Duct Tags Move when Offset is Changed?
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    205
    05:30 PM
    When I change the offset of some pipe of duct, the tags move along the pipe from where they were initially placed. Is this expected behaviour? The greater the change in the offset the more the tags seem to move.
    September 16, 2015
    Darwin, Australia
    171
    10:00 AM
    I haven't seen that behavior before, my tags never seem to move relative to the piece that is tagged. Have you ensured that your tag family is centered on the origin?
    December 29, 2014
    Calgary, Canada
    205
    05:30 PM
    That was what I first checked (and remedied). The tags still move, but not nearly as drastically. The tags that aren't on the piece of pipe that is changed are the ones that are most affected.
    Member RAJESH87's Avatar
    July 19, 2014
    CHENNAI, INDIA
    95
    05:00 AM
    yes, tags are moving when elevation level changed.
    September 16, 2015
    Darwin, Australia
    171
    10:00 AM
    I just checked in one of my current projects. It doesn't matter which way I move the part the tag stays in the exact position relative to the part being moved. I am using Fabrication Parts though, maybe Autodesk did something right in the fabrication department?
  1. Embedded door panel changed horizontal location when height parameter is changed
    By DavidLarson in forum Architecture - Family Creation
    Last Post: August 10th, 2015, 05:59 PM
  2. Duct fittings (reduction offset)
    By bartek_86 in forum MEP - General
    Last Post: January 14th, 2015, 01:54 PM
  3. Move Pipe Connectors in family
    By domsib in forum Architecture - Family Creation
    Last Post: March 18th, 2013, 10:35 AM
  4. Pipe Connectors move........
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: October 3rd, 2012, 09:20 AM
  5. offset and move vertically
    By Ning Zhou in forum Architecture - Family Creation
    Last Post: February 24th, 2012, 09:50 PM
Tags for this Thread
