Results 1 to 3 of 3
Thread: Revit 1016 with Fabrication ADD ON issues
    April 25, 2014
    Elllesmere Port, Cheshire, UK
    97
    01:10 AM
    Just started using Revit 2016 with the Fabrication Add on Package, I am trying to get to terms with using the fabrication parts available.
    just started doing some cable tray and looks good being able to use basket and supports.
    I started with ground floor but moving up to first floor i can still see all my cable tray from ground floor showing, i checked my view range and all seems ok. i tested it with using the revit cable tray and works as it should (no cable tray showing from ground floor).
    so it has to be a fabrication issue, so does anyone know how there how you create your views so you only see what is drawn in each floor?
    September 16, 2015
    Darwin, Australia
    171
    11:40 AM
    Hi Texas,
    I have been using Revit's Fabrication Parts for drawing duct work for over a month. I have not had this issue at all, my View Range filters out the unwanted geometry without issue. I have not tried drawing cable trays with it, however, I'm assuming all ITM files work in the same way regardless of service or specification. Which makes me think there is something not right in your project.
    I hate to ask, but have you triple checked the elevation of the cable tray? If that is not the case, there may be a cheeky little tick-box just waiting to be ticked/unticked. I'm not the best at explaining Revit's in's and out's (doubly so for anything view related), however, if you could up load the project with the issue in it I could have a closer look at the problem.
    Just on another note, do you intend to fabricate the cable tray in-house? If not I wouldn't recommend using Fabrication Parts just yet.
    Gold Coast
    2,631
    11:10 AM
    I know zip about cable trays or how they work in revit with your that addon, but have you checked your view underlay settings? Does any of the cable tray geometry (hangers?) extend up into the next levels view depth?
  1. Revit 2016 Fabrication Settings
    By Seahawk69 in forum MEP - General
    Last Post: August 20th, 2015, 06:59 PM
  2. Revit 2016: Add filters for fabrication part in 3D
    By swapr78 in forum MEP - General
    Last Post: July 7th, 2015, 12:27 PM
  3. Revit MEP 2016 Fabrication Parts
    By Chris.kershaw in forum MEP - General
    Last Post: May 4th, 2015, 06:22 PM
  4. Revit Kid: Autodesk Fabrication Website
    By The Revit Kid in forum Blog Feeds
    Last Post: June 28th, 2012, 05:15 PM
  5. What Revit Wants: Where fabrication and design meet
    By luke.johnson in forum Blog Feeds
    Last Post: November 8th, 2011, 11:45 PM
