Results 1 to 3 of 3
Thread: Riser Duct Visibility Issue
    December 20, 2010
    Pune,India
    89
    07:52 PM
    Angry Riser Duct Visibility Issue
    In my project I am facing an issue with visibility of fresh air riser duct. This riser duct running from GF to Third FF.This duct is visible at all floor levels except first floor level. If I disconnected a riser from a elbow which is @ 2300 below first floor level then duct is visible if i connect it to elbow then it is not visible. I had checked all possibilities related visibility but I am not able to fix it.
    Any suggestion?? Any clue??? to fix it.
    Member Jrobker's Avatar
    December 9, 2010
    Salt Lake
    178
    07:22 AM
    Sounds like you have a visibility setting defined by systems. When the duct is connected it becomes part of a system. Check in VG and look at your filters.
    December 20, 2010
    Pune,India
    89
    07:52 PM
    System Type
    At Last I found an issue.The issue is, I need a fresh air system for ducting and by default it is not available with RMEP so I added it as a other system.As their is no any default presentation for other system so that the riser duct is not visible in plan if it is connected fitting. As it disconnected from a fitting it becomes visible.
    I heard that in 2012 we will be able to add a new system type...hope so it will be work fine for 2012.
  1. Flush Side Duct Mounted Grilles
    By W.Neuok in forum MEP - Family Creation
    Last Post: May 29th, 2013, 03:47 PM
  2. Duct Visibility Elbow up vs Elbow dn
    By Gary Luisi in forum MEP - General
    Last Post: August 8th, 2011, 03:22 PM
  3. Duct Connector Configurations
    Last Post: July 19th, 2011, 02:48 PM
  4. Plumbing riser not cutting in plan
    Last Post: April 26th, 2011, 04:49 PM
  5. How can i create reducing duct elbows?
    By BWI-NL in forum MEP - General
    Last Post: March 3rd, 2011, 12:24 PM
Tags for this Thread
